C20 won't save SIP authentication login name/password after upgrade to 6.2
riboehm
I upgraded my C20 from 5.1.8 to 6.2.1 and it would no longer register with VCS with message 401 unauthorised.  I noticed the SIP Profile 1 Authentication LoginName and Password were empty.  When I attempt to add the username and password information back into these fields they initially save, but when refreshing or returning to the config page later they are blank again.  If I downgrade to 5.1.8 and re-enter the credentials everything works.
Any ideas?
Thanks!
amehla
Hi Ribo,
seems like you are hitting bug CSCuj48259
workaround will be to use device on TC 5.1.8
9 Replies 9
Martin Koch
I tested and set my EX90 with TC6.2 and set auth which worked fine and then upgraded to TC6.2.1
which still kept the config parameters and registers fine.
I also reset it with something wrong and it failed as expected, after reconfiguring it worked fine, also after a reboot.
I used the admin cli and set it via xconfig commands. How did you set it?
Any kind of non asci characters present in the password?
Would not be the first time that special characters break something.
If you could post the current configuration and how/what exactly you did might help us to understand.
I did not use a C20 but an EX90 but I would expect that they behave the same.
Please remember to rate helpful responses and identify helpful or correct answers.
I tried to enter the login name/password via the web interface, using the remote and finally via command line using xconfiguration.  None of these work.  The username is 4 letters, all lowercase and the password is a combination of letters and numbers, but neither have any special characters.  Here is a before and after xstatus and xconfiguration:
Thanks for the help!
Rich
Before Upgrade:
TANDBERG Codec Release TC5.1.8.303428
SW Release Date: 2013-06-06
OK
xstatus
*s Audio Microphones Mute: Off
*s Audio Volume: 70
*s Camera 1 Connected: False
*s Camera 1 HardwareID: ""
*s Camera 1 Manufacturer: ""
*s Camera 1 Model: ""
*s Camera 1 SoftwareID: ""
*s Camera 1 SerialNumber: ""
*s Camera 1 IpAddress: ""
*s Camera 1 MacAddress: ""
*s Camera 1 Position Pan: 0
*s Camera 1 Position Tilt: 0
*s Camera 1 Position Zoom: 16
*s Camera 1 Position Focus: 4000
*s Camera 1 Capabilities Options: ""
*s Camera 1 Flip: "Off"
*s Conference Presentation Mode: Off
*s Conference Presentation Protocol: ""
*s Conference Presentation Resolution Height: 0
*s Conference Presentation Resolution Width: 0
*s Conference Presentation SiteId: 0
*s Conference Presentation LocalSource: 0
*s Conference Multipoint Mode: "Off"
*s Conference DoNotDisturb: Inactive
*s Experimental Audio Input Connectors Microphone 1 Activity: False
*s Experimental Audio Input Connectors Microphone 2 Activity: False
*s Experimental Audio Input Connectors Line 1 Activity: False
*s Experimental Audio Input Connectors Line 2 Activity: False
*s H323 Gatekeeper Status: Rejected
*s H323 Gatekeeper Address: ""
*s H323 Gatekeeper Port: 0
*s H323 Gatekeeper Reason: "Empty GK string"
*s HttpFeedback 1 URL: ""
*s HttpFeedback 1 Expression: ""
*s HttpFeedback 2 URL: ""
*s HttpFeedback 2 Expression: ""
*s HttpFeedback 3 URL: ""
*s HttpFeedback 3 Expression: ""
*s HttpFeedback 4 URL: ""
*s HttpFeedback 4 Expression: ""
*s Network 1 Ethernet MacAddress: "00:50:60:0D:4C:E9"
*s Network 1 Ethernet Speed: "100full"
*s Network 1 IPv4 Address: "172.30.100.160"
*s Network 1 IPv4 SubnetMask: "255.255.255.0"
*s Network 1 IPv4 Gateway: "172.30.100.1"
*s Network 1 IPv4 DNS Domain Name: "cl.ri.cox.net"
*s Network 1 IPv4 DNS Server 1 Address: "68.105.28.11"
*s Network 1 IPv4 DNS Server 2 Address: "68.105.29.11"
*s Network 1 IPv4 DNS Server 3 Address: ""
*s Network 1 IPv4 DNS Server 4 Address: ""
*s Network 1 IPv4 DNS Server 5 Address: ""
*s Network 1 IPv6 Address: ""
*s Network 1 IPv6 Gateway: ""
*s Network 1 MTU: 1500
*s Network 1 VLAN Voice VlanId: "Off"
*s Preset 1 Defined: False
*s Preset 1 Type: All
*s Preset 1 Description: ""
*s Preset 2 Defined: False
*s Preset 2 Type: All
*s Preset 2 Description: ""
*s Preset 3 Defined: False
*s Preset 3 Type: All
*s Preset 3 Description: ""
*s Preset 4 Defined: False
*s Preset 4 Type: All
*s Preset 4 Description: ""
*s Preset 5 Defined: False
*s Preset 5 Type: All
*s Preset 5 Description: ""
*s Preset 6 Defined: False
*s Preset 6 Type: All
*s Preset 6 Description: ""
*s Preset 7 Defined: False
*s Preset 7 Type: All
*s Preset 7 Description: ""
*s Preset 8 Defined: False
*s Preset 8 Type: All
*s Preset 8 Description: ""
*s Preset 9 Defined: False
*s Preset 9 Type: All
*s Preset 9 Description: ""
*s Preset 10 Defined: False
*s Preset 10 Type: All
*s Preset 10 Description: ""
*s Preset 11 Defined: False
*s Preset 11 Type: All
*s Preset 11 Description: ""
*s Preset 12 Defined: False
*s Preset 12 Type: All
*s Preset 12 Description: ""
*s Preset 13 Defined: False
*s Preset 13 Type: All
*s Preset 13 Description: ""
*s Preset 14 Defined: False
*s Preset 14 Type: All
*s Preset 14 Description: ""
*s Preset 15 Defined: False
*s Preset 15 Type: All
*s Preset 15 Description: ""
*s Provisioning Status:
*s Provisioning Reason: ""
*s Provisioning Software UpgradeStatus SessionId: ""
*s Provisioning Software UpgradeStatus LastChange: "2013-09-17T17:23:34Z"
*s Provisioning Software UpgradeStatus Status: None
*s Provisioning Software UpgradeStatus Phase: None
*s Provisioning Software UpgradeStatus Message: ""
*s Provisioning Software UpgradeStatus VersionId: ""
*s Provisioning Software UpgradeStatus URL: ""
*s Provisioning Software Current VersionId: ""
*s Provisioning Software Current URL: ""
*s Provisioning Software Current CompletedAt: "2013-09-17T17:23:34Z"
*s Security FIPS Mode: Off
*s SIP Proxy 1 Status: Active
*s SIP Proxy 1 Address: "172.30.100.42"
*s SIP Proxy 1 Secure: True
*s SIP Proxy 1 Verified: False
*s SIP Registration 1 Status: Registered
*s SIP Registration 1 Reason: ""
*s SIP Registration 1 URI: "tata@land.com"
*s SIP Registration 1 Authentication: Digest
*s SIP Profile 1 Proxy 1 Status: Active
*s SIP Profile 1 Proxy 1 Address: "172.30.100.42"
*s SIP Profile 1 Secure: True
*s SIP Profile 1 Verified: False
*s SIP Profile 1 Authentication: Digest
*s SIP Profile 1 Registration 1 Status: Registered
*s SIP Profile 1 Registration 1 Reason: ""
*s SIP Profile 1 Registration 1 URI: "tata@land.com"
*s Standby Active: On
*s SystemUnit ProductType: "TANDBERG Codec"
*s SystemUnit ProductId: "TANDBERG Codec C20"
*s SystemUnit ProductPlatform: "C20"
*s SystemUnit Uptime: 27923
*s SystemUnit Software Application: "Endpoint"
*s SystemUnit Software Version: "TC5.1.8.303428"
*s SystemUnit Software Name: "s52000"
*s SystemUnit Software ReleaseDate: "2013-06-06"
*s SystemUnit Software MaxVideoCalls: 1
*s SystemUnit Software MaxAudioCalls: 2
*s SystemUnit Software ReleaseKey: "true"
*s SystemUnit Software OptionKeys NaturalPresenter: "true"
*s SystemUnit Software OptionKeys PremiumResolution: "true"
*s SystemUnit Software OptionKeys HighDefinition: "false"
*s SystemUnit Software OptionKeys DualDisplay: "true"
*s SystemUnit Hardware Module SerialNumber: "F1AN03E00386"
*s SystemUnit Hardware Module Identifier: "F0"
*s SystemUnit Hardware Module CompatibilityLevel: "0"
*s SystemUnit Hardware MainBoard SerialNumber: "PB0592755"
*s SystemUnit Hardware MainBoard Identifier: "101551-4 [2A]"
*s SystemUnit Hardware BootSoftware: "U-Boot 2010.06-108"
*s SystemUnit Hardware MonitoringSoftware: "46"
*s SystemUnit Hardware Monitoring Fan 1 Status: "locked on 4320 rpm"
*s SystemUnit Hardware Monitoring Fan 2 Status: "locked on 4320 rpm"
*s SystemUnit Hardware Temperature: "47.5"
*s SystemUnit State System: Initialized
*s SystemUnit State MaxNumberOfCalls: 2
*s SystemUnit State MaxNumberOfActiveCalls: 2
*s SystemUnit State NumberOfActiveCalls: 0
*s SystemUnit State NumberOfSuspendedCalls: 0
*s SystemUnit State NumberOfInProgressCalls: 0
*s SystemUnit State Subsystem Application: Initialized
*s SystemUnit ContactInfo: "tata@land.com"
*s Time ZoneOlson: America/New_York
*s Video Input LastConnectedSource: 0
*s Video Input Source 1 Resolution Height: 0
*s Video Input Source 1 Resolution Width: 0
*s Video Input Source 1 Resolution RefreshRate: 0
*s Video Input Source 1 Resolution FormatType: Unknown
*s Video Input Source 1 Resolution FormatStatus: Error
*s Video Input Source 2 Resolution Height: 0
*s Video Input Source 2 Resolution Width: 0
*s Video Input Source 2 Resolution RefreshRate: 0
*s Video Input Source 2 Resolution FormatType: Unknown
*s Video Input Source 2 Resolution FormatStatus: Error
*s Video Input HDMI 1 Connected: False
*s Video Input HDMI 1 SignalState: Unknown
*s Video Input DVI 2 Connected: False
*s Video Input DVI 2 SignalState: Unknown
*s Video Output HDMI 1 Resolution Height: 720
*s Video Output HDMI 1 Resolution Width: 1280
*s Video Output HDMI 1 Resolution RefreshRate: 60
*s Video Output HDMI 2 Resolution Height: 720
*s Video Output HDMI 2 Resolution Width: 1280
*s Video Output HDMI 2 Resolution RefreshRate: 60
*s Video Layout PresentationView: Default
*s Video Layout Site 1 Output 1 FamilyName: "fullscreen"
*s Video Layout Site 1 Output 1 FullFamilyName: "fullscreen-local-single-camctrl"
*s Video Layout Site 1 Output 1 GraphicName: "1"
*s Video Layout Site 1 Output 1 Frame 1 PositionX: 0
*s Video Layout Site 1 Output 1 Frame 1 PositionY: 0
*s Video Layout Site 1 Output 1 Frame 1 Width: 10000
*s Video Layout Site 1 Output 1 Frame 1 Height: 10000
*s Video Layout Site 1 Output 1 Frame 1 Layer: 1
*s Video Layout Site 1 Output 1 Frame 1 VideoSourceType: "graphic"
*s Video Layout Site 1 Output 1 Frame 1 VideoSourceId: 0
*s Video Layout Site 1 Output 1 Frame 1 InputNumber: 0
*s Video Layout Site 1 Output 1 Frame 1 Filename: "/apps/posters/waves.png"
*s Video Layout Site 1 Output 1 Frame 2 PositionX: 0
*s Video Layout Site 1 Output 1 Frame 2 PositionY: 0
*s Video Layout Site 1 Output 1 Frame 2 Width: 10000
*s Video Layout Site 1 Output 1 Frame 2 Height: 10000
*s Video Layout Site 1 Output 1 Frame 2 Layer: 0
*s Video Layout Site 1 Output 1 Frame 2 VideoSourceType: "site"
*s Video Layout Site 1 Output 1 Frame 2 VideoSourceId: 1
*s Video Layout Site 1 Output 1 Frame 2 InputNumber: 0
*s Video Layout Site 1 Output 1 Frame 2 Filename: ""
*s Video Layout Site 1 Output 1 Frame 3 PositionX: 7084
*s Video Layout Site 1 Output 1 Frame 3 PositionY: 7154
*s Video Layout Site 1 Output 1 Frame 3 Width: 2432
*s Video Layout Site 1 Output 1 Frame 3 Height: 2432
*s Video Layout Site 1 Output 1 Frame 3 Layer: 4
*s Video Layout Site 1 Output 1 Frame 3 VideoSourceType: "site"
*s Video Layout Site 1 Output 1 Frame 3 VideoSourceId: 1
*s Video Layout Site 1 Output 1 Frame 3 InputNumber: 1
*s Video Layout Site 1 Output 1 Frame 3 Filename: ""
*s Video Layout Site 1 Output 2 FamilyName: "fullscreen"
*s Video Layout Site 1 Output 2 FullFamilyName: "fullscreen-local-single-camctrl"
*s Video Layout Site 1 Output 2 GraphicName: "1"
*s Video Layout Site 1 Output 2 Frame 1 PositionX: 0
*s Video Layout Site 1 Output 2 Frame 1 PositionY: 0
*s Video Layout Site 1 Output 2 Frame 1 Width: 10000
*s Video Layout Site 1 Output 2 Frame 1 Height: 10000
*s Video Layout Site 1 Output 2 Frame 1 Layer: 1
*s Video Layout Site 1 Output 2 Frame 1 VideoSourceType: "graphic"
*s Video Layout Site 1 Output 2 Frame 1 VideoSourceId: 0
*s Video Layout Site 1 Output 2 Frame 1 InputNumber: 0
*s Video Layout Site 1 Output 2 Frame 1 Filename: "/apps/posters/waves.png"
*s Video Layout Site 1 Output 2 Frame 2 PositionX: 7084
*s Video Layout Site 1 Output 2 Frame 2 PositionY: 7154
*s Video Layout Site 1 Output 2 Frame 2 Width: 2432
*s Video Layout Site 1 Output 2 Frame 2 Height: 2432
*s Video Layout Site 1 Output 2 Frame 2 Layer: 4
*s Video Layout Site 1 Output 2 Frame 2 VideoSourceType: "site"
*s Video Layout Site 1 Output 2 Frame 2 VideoSourceId: 1
*s Video Layout Site 1 Output 2 Frame 2 InputNumber: 1
*s Video Layout Site 1 Output 2 Frame 2 Filename: ""
** end
OK
xconfiguration
*c xConfiguration Audio Microphones Mute Enabled: True
*c xConfiguration Audio Volume: 70
*c xConfiguration Audio SoundsAndAlerts RingVolume: 50
*c xConfiguration Audio SoundsAndAlerts RingTone: Marbles
*c xConfiguration Audio SoundsAndAlerts KeyTones Mode: On
*c xConfiguration Cameras PowerLine Frequency: 60Hz
*c xConfiguration Cameras Camera 1 Brightness Mode: Auto
*c xConfiguration Cameras Camera 1 Brightness Level: 1
*c xConfiguration Cameras Camera 1 Whitebalance Mode: Auto
*c xConfiguration Cameras Camera 1 Whitebalance Level: 1
*c xConfiguration Cameras Camera 1 Focus Mode: Auto
*c xConfiguration Cameras Camera 1 Backlight: Off
*c xConfiguration Cameras Camera 1 Mirror: Auto
*c xConfiguration Cameras Camera 1 Flip: Auto
*c xConfiguration Cameras Camera 1 DHCP: Off
*c xConfiguration Cameras Camera 1 Gamma Mode: Auto
*c xConfiguration Cameras Camera 1 Gamma Level: 0
*c xConfiguration Cameras Camera 1 IrSensor: On
*c xConfiguration Conference 1 AutoAnswer Mode: Off
*c xConfiguration Conference 1 AutoAnswer Mute: Off
*c xConfiguration Conference 1 AutoAnswer Delay: 0
*c xConfiguration Conference 1 MicUnmuteOnDisconnect Mode: On
*c xConfiguration Conference 1 DoNotDisturb Mode: Off
*c xConfiguration Conference 1 FarEndControl Mode: On
*c xConfiguration Conference 1 FarEndControl SignalCapability: On
*c xConfiguration Conference 1 Encryption Mode: BestEffort
*c xConfiguration Conference 1 DefaultCall Protocol: Sip
*c xConfiguration Conference 1 DefaultCall Rate: 1472
*c xConfiguration Conference 1 MaxTransmitCallRate: 6000
*c xConfiguration Conference 1 MaxReceiveCallRate: 6000
*c xConfiguration Conference 1 VideoBandwidth Mode: Dynamic
*c xConfiguration Conference 1 VideoBandwidth MainChannel Weight: 5
*c xConfiguration Conference 1 VideoBandwidth PresentationChannel Weight: 5
*c xConfiguration Conference 1 PacketLossResilience Mode: On
*c xConfiguration Conference 1 Presentation Policy: LocalRemote
*c xConfiguration Conference 1 Multipoint Mode: Auto
*c xConfiguration Conference 1 IncomingMultisiteCall Mode: Allow
*c xConfiguration Experimental Conference 1 ReceiverBasedDownspeeding: On
*c xConfiguration Experimental Conference 1 PacketLossResilience ForwardErrorCorrection: On
*c xConfiguration Experimental Conference 1 PacketLossResilience RateAdaption: On
*c xConfiguration Experimental Conference 1 Multistream Mode: Off
*c xConfiguration Experimental Conference 1 Multistream InputCount: 2
*c xConfiguration Experimental Conference 1 Multistream OutputCount: 1
*c xConfiguration Experimental Conference 1 Multistream Stream 1 Source: 1
*c xConfiguration Experimental Conference 1 Multistream Stream 2 Source: 1
*c xConfiguration Experimental Conference 1 Multistream Stream 3 Source: 1
*c xConfiguration Experimental Conference 1 Multistream Stream 4 Source: 1
*c xConfiguration Experimental CapsetFilter: ""
*c xConfiguration Experimental CapsetReduction: Auto
*c xConfiguration Experimental NetworkServices UPnP Mode: On
*c xConfiguration Experimental NetworkServices UPnP Timeout: 600
*c xConfiguration Experimental SystemUnit MenuType: Full
*c xConfiguration Experimental SystemUnit SoftwareUpgrade RequireAuthentication: On
*c xConfiguration Experimental SystemUnit CrashReporting Mode: Off
*c xConfiguration Experimental SystemUnit CrashReporting URI: ""
*c xConfiguration Experimental CTMSSupport Mode: On
*c xConfiguration Experimental CustomSoftbuttons HoldResume: Off
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 1 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 1 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 2 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 2 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 3 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 3 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 4 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 4 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 5 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 5 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 1 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 1 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 2 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 2 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 3 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 3 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 4 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 4 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 5 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 5 Value: ""
*c xConfiguration Experimental Audio Panning Mode: Off
*c xConfiguration Experimental Audio Panning MaxAngle: 60
*c xConfiguration Experimental Audio Panning MonitorLeft: 1
*c xConfiguration Experimental Audio Panning MonitorRight: 1
*c xConfiguration Experimental Audio EcReferenceDelay: 200
*c xConfiguration FacilityService Service 1 Type: Helpdesk
*c xConfiguration FacilityService Service 1 Name: ""
*c xConfiguration FacilityService Service 1 Number: ""
*c xConfiguration FacilityService Service 1 CallType: Video
*c xConfiguration FacilityService Service 2 Type: Helpdesk
*c xConfiguration FacilityService Service 2 Name: ""
*c xConfiguration FacilityService Service 2 Number: ""
*c xConfiguration FacilityService Service 2 CallType: Video
*c xConfiguration FacilityService Service 3 Type: Helpdesk
*c xConfiguration FacilityService Service 3 Name: ""
*c xConfiguration FacilityService Service 3 Number: ""
*c xConfiguration FacilityService Service 3 CallType: Video
*c xConfiguration FacilityService Service 4 Type: Helpdesk
*c xConfiguration FacilityService Service 4 Name: ""
*c xConfiguration FacilityService Service 4 Number: ""
*c xConfiguration FacilityService Service 4 CallType: Video
*c xConfiguration FacilityService Service 5 Type: Helpdesk
*c xConfiguration FacilityService Service 5 Name: ""
*c xConfiguration FacilityService Service 5 Number: ""
*c xConfiguration FacilityService Service 5 CallType: Video
*c xConfiguration H323 NAT Mode: Off
*c xConfiguration H323 NAT Address: ""
*c xConfiguration H323 Profile 1 H323Alias ID: ""
*c xConfiguration H323 Profile 1 H323Alias E164: ""
*c xConfiguration H323 Profile 1 PortAllocation: Dynamic
*c xConfiguration H323 Profile 1 CallSetup Mode: Gatekeeper
*c xConfiguration H323 Profile 1 Gatekeeper Address: ""
*c xConfiguration H323 Profile 1 Gatekeeper Discovery: Manual
*c xConfiguration H323 Profile 1 Authentication LoginName: ""
*c xConfiguration H323 Profile 1 Authentication Password: ""
*c xConfiguration H323 Profile 1 Authentication Mode: Off
*c xConfiguration Network 1 VLAN Voice Mode: Off
*c xConfiguration Network 1 VLAN Voice VlanId: 1
*c xConfiguration Network 1 Speed: Auto
*c xConfiguration Network 1 Assignment: DHCP
*c xConfiguration Network 1 IPStack: IPv4
*c xConfiguration Network 1 IPv6 Address: ""
*c xConfiguration Network 1 IPv6 Gateway: ""
*c xConfiguration Network 1 IPv6 Assignment: Autoconf
*c xConfiguration Network 1 IPv6 DHCPOptions: On
*c xConfiguration Network 1 QoS Mode: Diffserv
*c xConfiguration Network 1 QoS Diffserv Audio: 0
*c xConfiguration Network 1 QoS Diffserv Data: 0
*c xConfiguration Network 1 QoS Diffserv Signalling: 0
*c xConfiguration Network 1 QoS Diffserv Video: 0
*c xConfiguration Network 1 DNS Server 1 Address: "68.105.28.11"
*c xConfiguration Network 1 DNS Server 2 Address: "68.105.29.11"
*c xConfiguration Network 1 DNS Server 3 Address: "4.2.2.2"
*c xConfiguration Network 1 DNS Domain Name: "land.com"
*c xConfiguration Network 1 IEEE8021X Mode: Off
*c xConfiguration Network 1 IEEE8021X TlsVerify: Off
*c xConfiguration Network 1 IEEE8021X UseClientCertificate: Off
*c xConfiguration Network 1 IEEE8021X AnonymousIdentity: ""
*c xConfiguration Network 1 IEEE8021X Identity: ""
*c xConfiguration Network 1 IEEE8021X Password: ""
*c xConfiguration Network 1 IEEE8021X Eap Md5: On
*c xConfiguration Network 1 IEEE8021X Eap Ttls: On
*c xConfiguration Network 1 IEEE8021X Eap Tls: On
*c xConfiguration Network 1 IEEE8021X Eap Peap: On
*c xConfiguration Network 1 MTU: 1500
*c xConfiguration Network 1 TrafficControl Mode: On
*c xConfiguration Network 1 RemoteAccess Allow: ""
*c xConfiguration Network 1 IPv4 SubnetMask: ""
*c xConfiguration Network 1 IPv4 Gateway: ""
*c xConfiguration Network 1 IPv4 Address: ""
*c xConfiguration NetworkServices XMLAPI Mode: On
*c xConfiguration NetworkServices Telnet Mode: Off
*c xConfiguration NetworkServices SSH Mode: On
*c xConfiguration NetworkServices SSH AllowPublicKey: On
*c xConfiguration NetworkServices HTTP Mode: On
*c xConfiguration NetworkServices HTTPS Mode: On
*c xConfiguration NetworkServices HTTPS VerifyServerCertificate: Off
*c xConfiguration NetworkServices HTTPS VerifyClientCertificate: Off
*c xConfiguration NetworkServices HTTPS OCSP URL: ""
*c xConfiguration NetworkServices HTTPS OCSP Mode: Off
*c xConfiguration NetworkServices SNMP Mode: ReadOnly
*c xConfiguration NetworkServices SNMP CommunityName: "public"
*c xConfiguration NetworkServices SNMP SystemContact: ""
*c xConfiguration NetworkServices SNMP SystemLocation: ""
*c xConfiguration NetworkServices SNMP Host 1 Address: ""
*c xConfiguration NetworkServices SNMP Host 2 Address: ""
*c xConfiguration NetworkServices SNMP Host 3 Address: ""
*c xConfiguration NetworkServices H323 Mode: On
*c xConfiguration NetworkServices SIP Mode: On
*c xConfiguration NetworkServices NTP Mode: Auto
*c xConfiguration NetworkServices NTP Address: "1.ntp.tandberg.com"
*c xConfiguration NetworkServices MultiWay Address: ""
*c xConfiguration NetworkServices MultiWay Protocol: Auto
*c xConfiguration Phonebook Server 1 ID: ""
*c xConfiguration Phonebook Server 1 Type: TMS
*c xConfiguration Phonebook Server 1 URL: ""
*c xConfiguration Provisioning Mode: TMS
*c xConfiguration Provisioning LoginName: ""
*c xConfiguration Provisioning Password: ""
*c xConfiguration Provisioning HttpMethod: POST
*c xConfiguration Provisioning ExternalManager Address: ""
*c xConfiguration Provisioning ExternalManager Protocol: HTTP
*c xConfiguration Provisioning ExternalManager Path: ""
*c xConfiguration Provisioning ExternalManager Domain: ""
*c xConfiguration Provisioning Connectivity: Auto
*c xConfiguration RTP Ports Range Start: 2326
*c xConfiguration RTP Ports Range Stop: 2486
*c xConfiguration Security Audit Server Address: ""
*c xConfiguration Security Audit Server Port: 514
*c xConfiguration Security Audit OnError Action: Ignore
*c xConfiguration Security Audit Logging Mode: Off
*c xConfiguration Security Session ShowLastLogon: Off
*c xConfiguration Security Session InactivityTimeout: 0
*c xConfiguration SerialPort Mode: On
*c xConfiguration SerialPort BaudRate: 38400
*c xConfiguration SerialPort LoginRequired: On
*c xConfiguration SIP Profile 1 URI: "tata@land.com"
*c xConfiguration SIP Profile 1 DisplayName: "tata"
*c xConfiguration SIP Profile 1 DefaultTransport: Auto
*c xConfiguration SIP Profile 1 TlsVerify: Off
*c xConfiguration SIP Profile 1 Type: Standard
*c xConfiguration SIP Profile 1 Outbound: Off
*c xConfiguration SIP Profile 1 Proxy 1 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 1 Address: "172.30.100.42"
*c xConfiguration SIP Profile 1 Proxy 2 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 2 Address: ""
*c xConfiguration SIP Profile 1 Proxy 3 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 3 Address: ""
*c xConfiguration SIP Profile 1 Proxy 4 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 4 Address: ""
*c xConfiguration SIP Profile 1 Authentication 1 LoginName: "tata"
*c xConfiguration SIP Profile 1 Authentication 1 Password: "***"
*c xConfiguration Standby Control: On
*c xConfiguration Standby Delay: 5
*c xConfiguration Standby WakeupAction: DefaultCameraPosition
*c xConfiguration Standby BootAction: DefaultCameraPosition
*c xConfiguration Standby StandbyAction: PrivacyPosition
*c xConfiguration SystemUnit Type: Shared
*c xConfiguration SystemUnit Name: "tata"
*c xConfiguration SystemUnit MenuLanguage: English
*c xConfiguration SystemUnit ContactInfo Type: Auto
*c xConfiguration SystemUnit CallLogging Mode: On
*c xConfiguration SystemUnit IrSensor: Auto
*c xConfiguration Time Zone: GMT-05:00 (Eastern Time (US & Canada))
*c xConfiguration Time TimeFormat: 12H
*c xConfiguration Time DateFormat: MM_DD_YY
*c xConfiguration UserInterface TouchPanel DefaultPanel: ContactList
*c xConfiguration Video AllowWebSnapshots: Off
*c xConfiguration Video SelfviewPosition: LowerRight
*c xConfiguration Video Selfview: On
*c xConfiguration Video Wallpaper: Custom
*c xConfiguration Video MainVideoSource: 1
*c xConfiguration Video DefaultPresentationSource: 2
*c xConfiguration Video Layout Scaling: On
*c xConfiguration Video Layout ScaleToFrame: MaintainAspectRatio
*c xConfiguration Video Layout ScaleToFrameThreshold: 6
*c xConfiguration Video Layout LocalLayoutFamily: Auto
*c xConfiguration Video Layout RemoteLayoutFamily: Auto
*c xConfiguration Video Monitors: Single
*c xConfiguration Video OSD Mode: On
*c xConfiguration Video OSD AutoSelectPresentationSource: Off
*c xConfiguration Video OSD TodaysBookings: Off
*c xConfiguration Video OSD MyContactsExpanded: On
*c xConfiguration Video OSD Output: 1
*c xConfiguration Video OSD InputMethod InputLanguage: Latin
*c xConfiguration Video OSD InputMethod Cyrillic: Off
*c xConfiguration Video OSD LoginRequired: Off
*c xConfiguration Video Input Source 1 Name: "Camera"
*c xConfiguration Video Input Source 1 Connector: HDMI
*c xConfiguration Video Input Source 1 Type: camera
*c xConfiguration Video Input Source 1 CameraControl Mode: On
*c xConfiguration Video Input Source 1 CameraControl CameraId: 1
*c xConfiguration Video Input Source 1 Quality: Motion
*c xConfiguration Video Input Source 1 OptimalDefinition Profile: Normal
*c xConfiguration Video Input Source 1 OptimalDefinition Threshold60fps: 1280_720
*c xConfiguration Video Input Source 2 Name: "PC"
*c xConfiguration Video Input Source 2 Connector: DVI
*c xConfiguration Video Input Source 2 Type: PC
*c xConfiguration Video Input Source 2 CameraControl Mode: Off
*c xConfiguration Video Input Source 2 CameraControl CameraId: 1
*c xConfiguration Video Input Source 2 Quality: Sharpness
*c xConfiguration Video Input Source 2 OptimalDefinition Profile: Normal
*c xConfiguration Video Input Source 2 OptimalDefinition Threshold60fps: 1280_720
*c xConfiguration Video Input DVI 2 Type: AutoDetect
*c xConfiguration Video Output HDMI 1 Resolution: Auto
*c xConfiguration Video Output HDMI 1 OverscanLevel: Medium
*c xConfiguration Video Output HDMI 1 CEC Mode: Off
*c xConfiguration Video Output HDMI 1 MonitorRole: First
*c xConfiguration Video Output HDMI 2 Resolution: Auto
*c xConfiguration Video Output HDMI 2 OverscanLevel: None
*c xConfiguration Video Output HDMI 2 CEC Mode: Off
*c xConfiguration Video Output HDMI 2 MonitorRole: Second
** end
OK
After Upgrade:
TANDBERG Codec Release TC6.2.1.69d401c
SW Release Date: 2013-09-10
OK
xstatus
*s Audio Volume: 70
*s Conference ActiveSpeaker Mode: Auto
*s Conference ActiveSpeaker SiteId: 0
*s Conference Presentation LastLocalSource: 0
*s Conference Multipoint Mode: Off
*s Experimental Diagnostics Mode: Off
*s Experimental NumberOfVideoResourcesLeft: 1
*s Experimental NumberOfAudioResourcesLeft: 2
*s H320 Gateway Status: Inactive
*s H320 Gateway Address: ""
*s H320 Gateway Number: ""
*s H320 Gateway Mode: Unknown
*s H320 Gateway Reason: ""
*s H320 Gateway Id: ""
*s H323 Gatekeeper Status: Inactive
*s H323 Gatekeeper Reason: "Missing E164 alias or H323Id"
*s Network 1 IPv4 DHCP TftpServerAddress: ""
*s Network 1 IPv4 DHCP TmsServer: ""
*s Network 1 IPv4 DHCP ProvisioningServer: ""
*s Network 1 IPv4 DHCP ProvisioningDomain: ""
*s Network 1 IPv4 DHCP TftpServer: ""
*s Network 1 VLAN Native VlanId: "1"
*s Network 1 CDP Platform: "Cisco CISCO1941/K9"
*s Network 1 CDP Version: "Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1
(4)M4, RELEASE SOFTWARE (fc1)*Technical Support: http://www.cisco.com/techsupport*Copyright (c)
1986-2012 by Cisco Systems, Inc.*Compiled Tue 20-Mar-12 17:58 by prod_rel_team"
*s Network 1 CDP Capabilities: "0x0029"
*s Network 1 CDP DeviceId: "c1941"
*s Network 1 CDP PortID: "FastEthernet0/0/2"
*s Network 1 CDP Duplex: "Full"
*s Network 1 CDP VTPMgmtDomain: "phil"
*s Network 1 CDP Address: "172.30.100.1"
*s Network 1 CDP PrimaryMgmtAddress: ""
*s Network 1 CDP SysName: ""
*s Network 1 CDP SysObjectID: ""
*s Network 1 CDP VoIPApplianceVlanID: "None"
*s NetworkServices NTP Address: ""
*s Provisioning Status: NeedConfig
*s Provisioning Server: ""
*s Provisioning Software UpgradeStatus LastChange: "2013-09-18T01:24:31Z"
*s Provisioning Software UpgradeStatus SecondsUntilUpgrade: 0
*s Provisioning Software Current CompletedAt: "2013-09-18T01:24:31Z"
*s Provisioning CUCM CAPF Mode: IgnoreAuth
*s Provisioning CUCM CAPF ServerName: ""
*s Provisioning CUCM CAPF ServerPort: 0
*s Provisioning CUCM CAPF LSC: NotInstalled
*s Provisioning CUCM CAPF OperationState: NonPending
*s Provisioning CUCM CAPF OperationResult: NotSet
*s Provisioning CUCM ProvisionSecurity: None
*s Provisioning CUCM CTL State: NotInstalled
*s Provisioning CUCM ITL State: NotInstalled
*s SIP Proxy 1 Secure: False
*s SIP Registration 1 Status: Failed
*s SIP Registration 1 Reason: "401 Unauthorised"
*s SIP Registration 1 Authentication: Off
*s SIP Profile 1 Secure: False
*s SIP Profile 1 Authentication: Off
*s SIP Profile 1 Mailbox MessagesWaiting: 0
*s SIP Profile 1 CallForward Mode: Off
*s SIP Profile 1 CallForward URI: ""
*s SIP Profile 1 CallForward DisplayName: ""
*s SIP Profile 1 Registration 1 Status: Failed
*s SIP Profile 1 Registration 1 Reason: "401 Unauthorised"
*s ICE Configured: "Off"
*s ICE Defaultcandidate: ""
*s SystemUnit Uptime: 36674
*s SystemUnit Software Version: "TC6.2.1.69d401c"
*s SystemUnit Software ReleaseDate: "2013-09-10"
*s SystemUnit Hardware BootSoftware: "U-Boot 2010.06-113"
*s SystemUnit Hardware Temperature: "46.5"
*s SystemUnit Hardware TemperatureThreshold: "85"
*s SystemUnit ContactInfo: "172.30.100.160"
*s SystemUnit ContactName: "tata"
*s SystemUnit Diagnostics LastRun: "2013-09-18T11:34:58Z"
*s SystemUnit Diagnostics Message 1 Type: DefaultCallProtocolRegistered
*s SystemUnit Diagnostics Message 1 Level: Warning
*s SystemUnit Diagnostics Message 1 Description: "Not registered on default call protocol"
*s SystemUnit Diagnostics Message 1 References: ""
*s SystemUnit Diagnostics Message 2 Type: CamerasDetected
*s SystemUnit Diagnostics Message 2 Level: Warning
*s SystemUnit Diagnostics Message 2 Description: "No camera is detected"
*s SystemUnit Diagnostics Message 2 References: ""
*s SystemUnit Diagnostics Message 5 Type: SIPProfileRegistration
*s SystemUnit Diagnostics Message 5 Level: Error
*s SystemUnit Diagnostics Message 5 Description: "Sip profile registration failed"
*s SystemUnit Diagnostics Message 5 References: ""
*s Time SystemTime: "2013-09-18T11:35:27Z"
*s Video Layout Mode: Default
*s Video Layout Site 1 Output 1 FamilyName: "equal"
*s Video Layout Site 1 Output 1 FullFamilyName: "equal_local_single"
*s Video Layout Site 1 Output 1 GraphicName: "fullscreen"
*s Video Layout Site 1 Output 1 Frame 0 PositionX: 0
*s Video Layout Site 1 Output 1 Frame 0 PositionY: 0
*s Video Layout Site 1 Output 1 Frame 0 Width: 10000
*s Video Layout Site 1 Output 1 Frame 0 Height: 10000
*s Video Layout Site 1 Output 1 Frame 0 Layer: 0
*s Video Layout Site 1 Output 1 Frame 0 VideoSourceContent: gui
*s Video Layout Site 1 Output 1 Frame 0 VideoSourceType: "site"
*s Video Layout Site 1 Output 1 Frame 0 VideoSourceId: 1
*s Video Layout Site 1 Output 1 Frame 0 InputNumber: 0
*s Video Layout Site 1 Output 1 Frame 0 Filename: ""
*s Video Layout Site 1 Output 1 Frame 1 VideoSourceContent: wallpaper
*s Video Layout Site 1 Output 1 Frame 1 Filename: "/user/posters/wallpaper.png"
*s Video Layout Site 1 Output 1 Frame 4 PositionX: 7487
*s Video Layout Site 1 Output 1 Frame 4 PositionY: 7499
*s Video Layout Site 1 Output 1 Frame 4 Width: 2409
*s Video Layout Site 1 Output 1 Frame 4 Height: 2409
*s Video Layout Site 1 Output 1 Frame 4 Layer: 4
*s Video Layout Site 1 Output 1 Frame 4 VideoSourceContent: selfviewPip
*s Video Layout Site 1 Output 1 Frame 4 VideoSourceType: "site"
*s Video Layout Site 1 Output 1 Frame 4 VideoSourceId: 1
*s Video Layout Site 1 Output 1 Frame 4 InputNumber: 1
*s Video Layout Site 1 Output 1 Frame 4 Filename: ""
*s Video Layout Site 1 Output 2 FamilyName: "equal"
*s Video Layout Site 1 Output 2 FullFamilyName: "equal_local_single"
*s Video Layout Site 1 Output 2 GraphicName: "fullscreen"
*s Video Layout Site 1 Output 2 Frame 1 VideoSourceContent: wallpaper
*s Video Layout Site 1 Output 2 Frame 1 Filename: "/user/posters/wallpaper.png"
*s Video Layout Site 1 Output 2 Frame 4 PositionX: 7487
*s Video Layout Site 1 Output 2 Frame 4 PositionY: 7499
*s Video Layout Site 1 Output 2 Frame 4 Width: 2409
*s Video Layout Site 1 Output 2 Frame 4 Height: 2409
*s Video Layout Site 1 Output 2 Frame 4 Layer: 4
*s Video Layout Site 1 Output 2 Frame 4 VideoSourceContent: selfviewPip
*s Video Layout Site 1 Output 2 Frame 4 VideoSourceType: "site"
*s Video Layout Site 1 Output 2 Frame 4 VideoSourceId: 1
*s Video Layout Site 1 Output 2 Frame 4 InputNumber: 1
*s Video Layout Site 1 Output 2 Frame 4 Filename: ""
*s Video PIP ActiveSpeaker Position: UpperCenter
*s Video PIP Presentation Position: CenterLeft
*s Video Selfview Mode: On
*s Video Selfview FullscreenMode: Off
*s Video Selfview PIPPosition: LowerRight
*s Video Selfview OnMonitorRole: First
*s Video Input Source 1 MediaChannelId: 2
*s Video Input Source 1 Resolution FormatStatus: Ok
*s Video Input Source 2 MediaChannelId: 3
*s Video Input Source 2 Resolution FormatStatus: Ok
*s Video Output HDMI 1 Connected: True
*s Video Output HDMI 2 Connected: False
** end
OK
xconfiguration
*c xConfiguration Cameras Camera 1 Brightness Level: 20
*c xConfiguration Cameras Camera 1 MotorMoveDetection: Off
*c xConfiguration Conference 1 DoNotDisturb DefaultTimeout: 60
*c xConfiguration Conference 1 CallProtocolIPStack: IPv4
*c xConfiguration Conference 1 MaxTotalTransmitCallRate: 10000
*c xConfiguration Conference 1 MaxTotalReceiveCallRate: 10000
*c xConfiguration Conference 1 Presentation RelayQuality: Sharpness
*c xConfiguration Conference 1 Presentation OnPlacedOnHold: NoAction
*c xConfiguration Conference 1 LyncCompatibility Mode: Off
*c xConfiguration Experimental AudioPair Volume: 70
*c xConfiguration Experimental Ares: Off
OnWithUniqueSsrc
*c xConfiguration Experimental Conference 1 ActiveControl Mode: Off
*c xConfiguration Experimental Conference 1 FarendMessage Mode: Off
*c xConfiguration Experimental Byod Mode: Off
*c xConfiguration Experimental Byod CachedSnapshots: 10
*c xConfiguration Experimental NetworkServices Medianet Metadata: Off
*c xConfiguration Experimental SystemUnit RunStartupWizard: False
*c xConfiguration Experimental SystemUnit CrashReporting Mode: On
*c xConfiguration Experimental SystemUnit CrashReporting URL: "acr.rd.tandberg.com"
*c xConfiguration Experimental Video H263IntraFrameInterval: 0
*c xConfiguration Network 1 IPStack: Dual
*c xConfiguration Network 1 DHCP RequestTFTPServerAddress: Off
*c xConfiguration Network 1 QoS Diffserv ICMPv6: 0
*c xConfiguration Network 1 QoS Diffserv NTP: 0
*c xConfiguration Network 1 IPv4 Assignment: DHCP
*c xConfiguration NetworkServices CTMS Mode: On
*c xConfiguration NetworkServices CTMS Encryption: Off
*c xConfiguration Provisioning Mode: Auto
*c xConfiguration SIP Profile 1 Authentication 1 LoginName: ""
*c xConfiguration SIP Profile 1 Authentication 1 Password: ""
*c xConfiguration SIP Profile 1 Mailbox: ""
*c xConfiguration SIP Profile 1 Line: Shared
*c xConfiguration SIP Profile 1 Ice Mode: Off
*c xConfiguration SIP Profile 1 Ice DefaultCandidate: Host
*c xConfiguration SIP Profile 1 Turn Server: ""
*c xConfiguration SIP Profile 1 Turn UserName: ""
*c xConfiguration SIP Profile 1 Turn Password: ""
*c xConfiguration SIP ListenPort: On
*c xConfiguration Video SelfviewControl AutoResizing: On
*c xConfiguration Video SelfviewDefault Mode: Current
*c xConfiguration Video SelfviewDefault FullscreenMode: Current
*c xConfiguration Video SelfviewDefault PIPPosition: Current
*c xConfiguration Video SelfviewDefault OnMonitorRole: Current
*c xConfiguration Video CamCtrlPip CallSetup Mode: On
*c xConfiguration Video CamCtrlPip CallSetup Duration: 10
*c xConfiguration Video PIP ActiveSpeaker DefaultValue Position: Current
*c xConfiguration Video PIP Presentation DefaultValue Position: Current
*c xConfiguration Video OSD MenuStartupMode: Home
*c xConfiguration Video OSD VirtualKeyboard: UserSelectable
*c xConfiguration Video OSD EncryptionIndicator: Auto
*c xConfiguration Video OSD MissedCallsNotification: On
*c xConfiguration Video OSD WallPaperSelection: On
*c xConfiguration Video OSD LanguageSelection: On
*c xConfiguration Video Input Source 1 PresentationSelection: Manual
*c xConfiguration Video Input Source 2 PresentationSelection: Manual
*c xConfiguration Video Input HDMI 1 RGBQuantizationRange: Auto
*c xConfiguration Video Input DVI 2 RGBQuantizationRange: Full
*c xConfiguration Video Output HDMI 1 RGBQuantizationRange: Full
*c xConfiguration Video Output HDMI 2 RGBQuantizationRange: Full
** end
OK
This matches the issue exactly. Thanks.
Hi Ribo,
you can try below workaround on TC 6.2
In TC6.2 you must disable provisioning before sip authentication will work.
amehla
Hi Ribo,
Hi, has this bug been resolved yet?
I have noticed that many devices TC 6.2.1 show:
br. Tom
Tom: do you use the webinterface or the command line to set the username / password?
If webinterface, can you try ssh and xconfig?
This defect has not yet been resolved, however it is being addressed in a future software release. If you are running TC 6.2 or higher you will have this issue if you have your provisioning mode set to auto and the auto discovery of a provisioning back end succeeds but supplys a blank username and password to your system. Also, if it is set to auto and DHCP option 150 is configured on that network, it will attempt to provision with CUCM which would clear these fields.
If you have this issue, simply set your provisioning mode to off and the issue will go away.
xConfiguration Provisioning Mode: Off
The company's C60 (TC7.1.4) also has this problem. I'll try this configuration tomorrow. Can I solve this problem? Waiting for my good news.
