C40 upgrade from 5.1.8 to 7.3.3
devraj123
Hi All,
I am upgrading c40 codec from TC 5.1.8  to TC 7.3.3 .  I downloaded release key and TC 7.3.3 soft.
if something goes wrong while upgrading then can I rollback it to current one? Is there such option to rollback,if yes then how.
Please assist me on this.
Deva
2 Accepted Solutions
Patrick Sparkman
You can switch back to TC5 if you find that for some reason you want or need to.  There are always two software images stored on the codec, the current active software image and a second.  When software upgrades are performed, the upgrade will overwrite whichever is the inactive or older image, and after the upgrade the software version you were running will become the second inactive image and you can switch to this second image if you need for whatever reason.  Note, a factory reset will clear the 2nd software image stored on the codec.  See the C40 Admin Guide on pg 58 for more details.
If you SSH or Telnet in to the device, take a capture of the output of an "xconfiguration" command. This contains the important endpoint configuration which can be used to reconfigure it in the event of complete failure.
Upgrading the endpoint will still keep the original configuration in the 2nd software installation, and the selectsw switch previously mentioned will also restore the previous configuration.
Wayne
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
6 Replies 6
Patrick Sparkman
Cheers Patrick,
Wayne DeNardi
To roll back, once you have TC7.3.3 installed, log in to the web interface, go to Maintenance, System Recovery, then The Software Recovery Swap tab.  You will then see a "Switch to software: <previous software version> button which you can click to revert to the previous version.
If for some reason you can't get the web page option, you can do it via the CLI with the systemtools selectsw command.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Hope you doing well,
I have one question: just before upgrading from 5.1.8 to 7.3.3 , i want c40 codec to take backup.but i am unable to see any backup tab/parameter under maintainace.
Can you please help how can I do backup(currentlyc40 is running 5.1.8)
Deva
Wayne
Wayne
Hi All,
Thanks for precious info. I came to upgrade c40 successfully and checked working fine.
Cheers
