07-03-2013 07:17 AM - edited 03-18-2019 01:24 AM
All,
Got a customer who is running JITC TC3.5.3 on a C60, has the MS key installed, however we still cannot make MS calls, whats the deal?
Here are the current settings & or statuses:
xConfiguration Conference 1 IncomingMultisiteCall Mode: Allow
xstatus SystemUnit Software OptionKeys MultiSite: “true”
xstatus SystemUnit State MaxNumberOfCalls: 3
xstatus SystemUnit State MaxNumberOfActiveCalls: 3
Thank you,
Justin Ferello
Technical Support Specialist
KBZ, a Cisco Authorized Distributor
http://www.kbz.com
e/v: justin.ferello@kbz.com
07-03-2013 09:14 AM
Hi Justin,
Does the end customer see any error message on the screen like "Max calls has been reached"?
Was the MS feature working fine earlier on this unit or you have recently purchased MS license?
07-03-2013 09:31 AM
Mukesh,
No error messages, they dial the second endpoint and the first one goes on hold, then they can switch back and forth. If they receieve a call while on with another endpoint it only asks them the following:
Accept & put current call on hold
Accept & disconnect current call
Decline call
Also, the just bought the MS key, so it was never working to begin with.
Thank you,
Justin Ferello
http://www.kbz.com
07-03-2013 10:29 AM
Check multiway config, disable it.
Sent from Cisco Technical Support Android App
07-03-2013 10:34 AM
For normal ms call you will not get hold resume option and if ms key is not installed then 2nd call will connect as audio call. It looks multiply config is causing this issue. If config is ok then try factory reset.
07-03-2013 10:55 AM
Dharmesh,
I do not see anyway to disable MW, if I remember correctly as long as you had nothing in the 'address' field it was disabled...
This is all I see for MW:
NetworkServices
MultiWay
Address: Click to edit...
Protocol: Auto
We did perform a factory reset with no help.
Thank you,
Justin Ferello
http://www.kbz.com
07-03-2013 12:08 PM
Hi Justin,
Is it possible to try software upgrade on this device to TC5.1.8 or TC6.1.2 version?
07-03-2013 12:30 PM
Mukesh,
Customer does not appear to have a valid contract at this time, plus this will be a classified system so they will need JITC software.
Thank you,
Justin Ferello
http://www.kbz.com
07-03-2013 12:41 PM
Hi There
What is the codec's “MaxTotalRecieveCallRate” and “MaxTotalTransmiteCallRate” set to?
Also what is the default call rate set to.
Perhaps the first call is using all the allocated bandwidth and the codec will not accept any further calls.
I don’t know if the C codec’s automatically downspeed participants like the MXP systems did when adding multisite participants.
Also check the below settings.
Conference
Also with regards to the software version you should be able to claim a free software upgrade under the below security advisory notification from Cisco released 2 weeks ago.
TC3.0 software was one of the affected releases.
http://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20130619-tpc
