CAB-P6000-PHD-1M= alternative
Dear All
Can you any one convey alternative for CAB-P6000-PHD-1M=????
7 Replies 7
Patrick Sparkman
There is no replacement cable for CAB-P6000-PHD-1M as the MXP codecs have been end of sale since 2013, however you might be able to make your own cable, take a look at the "Cable Specifications" section in the MXP Admin Guide starting on pg 122.
Thanks Patrick for the support
Correct me if i am wrong the same is used to connect camera with cable?
Which cable we can use and other end will be what?
Please clarify in detail thanks
What type of camera are you using with the MXP, it can either be a Wave II or a PrecisionHD 730p? It will determine what cable you need.
Attached is he picture of cable that require...
can you confirm which one i can order.
If you require CAB-P6000-PHD-1M which is the camera cable of Precision HD 720p camera for 6000 MXP codec, the attached image you provided is needed.
regards,
Acevirgil
Thanks for your support.
same SKU is EOS,any alternative available?
As an alternative, you can customize a camera cable for this.
For reference see page 14 on this guide:
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/mxp-series/f9/user_guide/mxp_codec3000-6000_physical_interface_guide.pdf
regards,
Acevirgil
