11-04-2015 03:27 AM - edited 03-18-2019 05:10 AM
Hello guys,
I ran the following command xcommand CallHistory Get to extract the CDR from my SX80, but I noticed that the duration time is in days ago.
I need to know if there is any other way to extract the CDR that allows me to know the exactly duration of the call in hh:mm:ss .
Thanks in advance.
Regards.
Solved! Go to Solution.
11-04-2015 03:38 AM
If you do a xcommand CallHistory Get DetailLevel: Full it will show you the start and end from which you could derive the call duration.
Sebastian
11-04-2015 03:38 AM
Sebastian
11-04-2015 04:47 AM
Hi Sebastian,
It worked perfectly!
Thanks a lot for your attention.
Regards.
