Call details record
vnocpadrao
Hello guys,
I ran the following command xcommand CallHistory Get to extract the CDR from my SX80, but I noticed that the duration time is in days ago.
I need to know if there is any other way to extract the CDR that allows me to know the exactly duration of the call in hh:mm:ss .
Thanks in advance.
Regards.
Sebastian Hughes
If you do a xcommand CallHistory Get DetailLevel: Full it will show you the start and end from which you could derive the call duration.
Sebastian
Sebastian Hughes
Sebastian
Hi Sebastian,
It worked perfectly!
Thanks a lot for your attention.
Regards.
