call disconnection
elite2010
Level 3
Level 3
call disconnected  unexpectedly after a fixed period of time . Out of two calls it happened only with one call .
So there is no pattern for the issue happened .
Firewall is ASA
Expressway with two nic
How can I know the exact issue
Randy Valverde Rojas
You will need to be able to reproduce this and collect diagnostic logs from the expressways (Maintenance >> Diagnostics >> Diagnostic Logging).
When calls disconnect at a fixed amount of time on 15 minute intervals (15-30-45-60) usually points to a firewall dropping tcp connections due to lack of traffic, this block the SIP refresh causing the call to time out, though no way to confirm for sure without logs.
due to lack of traffic means , the internet is down or something ....?
Once connected log , What is there need to be verified (How to analyze the log ) ?
The frequency of disconnection  is like 1:02 minute and the call disconnected again after passing next 1:02 minutes
To analize the call on the logs you will want to look for the SIP invite if on SIP, and then follow that call ID to see where and why it disconnected.
