07-06-2005 08:25 PM - edited 03-17-2019 08:28 PM
Do video end points need to register to a gatekeeper for CallManager 4 to resolve e.164 addresses or can CM take the place of the gatekeeper and handle all resolution? Either way, what enhancement is gained by using CM instead of solely using the gatekeeper for E.164 resolution?
This URL shows that the gatekeeper proxies for the CM.
07-12-2005 11:51 AM
You can configure a H.323 client with the E.164 address that is registered with the gatekeeper. E.164 addressing facilitates H.323 configuration and call routing by allowing the Cisco CallManager to route all calls in place of the gatekeeper. The gatekeeper that is to be configured requires the following characteristics:
Forward all calls to the Cisco CallManager for routing.
Calls that are routed from the Cisco CallManager must not be routed back to the Cisco CallManager
07-12-2005 01:01 PM
Can this be done without the gatekeeper just using the CallManager?
07-12-2005 03:53 PM
No...
CallManager can not act as a Gatekeeper and thereby will not allow endpoints to register directly to it.
