Calls from Expressway-C to Expressway-E getting rejected after few seconds / MRA
jelcham
Hello Gents,
I am running into an issue with a deployment involving Mobile Remote Access using Expressway C & E.
The components involved are as follows:
CUCM: 9.1.2.10000-28
CUC:  9.1.2.10000-10
IMP: 9.1.1.41900-1
Expressway: X8.5.1
In fact, Jabber clients on the outside network are registering correctly with the CUCM and can make calls to internal DNs with no problem. Here is the Expressway zone routing (Which is pretty standard for a MRA deployment):
EXP-E: CollaborationEdgeZone -> CollaborationEdgeZToTraversalSZ -> TraversalSubZone -> Zone003ToTraversalSZ -> Unified Communication Manager Zone
EXP-C: Unified Communication Manager Zone -> Zone004ToTraversalSZ -> TraversalSubZone -> Zone002ToTraversalSZ -> CEtcp-172.16.142.41
However, when calling from an internal DN (registered to CUCM) to a Jabber located on the outside network, I am getting a rejected call with response 487. It says it might be related to inter-working issues but I cannot see why.
The zone routing is as follows:
EXP-C: CEtcp-172.16.142.41 -> Zone002ToTraversalSZ -> TraversalSubZone -> Zone004ToTraversalSZ -> Unified Communication Manager Zone
EXP-E: Unified Communication Manager Zone -> Zone003ToTraversalSZ -> TraversalSubZone -> CollaborationEdgeZToTraversalSZ -> CollaborationEdgeZone
Only SIP is enabled in the deployment.
The call events related to this call are the following:
2015-05-19T11:02:49+03:00tvcs: Event="Call Rejected" Service="SIP" Src-ip="172.16.146.36" Src-port="5073" Src-alias-type="SIP" Src-alias="sip:1111@172.16.142.41" Dst-alias-type="SIP" Dst-alias="sip:bd4de6b0-8f1e-c91c-215f-a84178316e91@10.113.50.157" Call-serial-number="60475a44-31c1-446c-bfc6-309f5f9a27db" Tag="1b86cd87-52b2-41f0-bab2-41230bdb3465" Detail="Request Terminated" Protocol="TLS" Response-code="487" Level="1" UTCTime="2015-05-19 08:02:49,716"
2015-05-19T11:02:49+03:00tvcs: Event="Search Cancelled" Service="SIP" Src-alias-type="SIP" Src-alias="1111@172.16.142.41" Dst-alias-type="SIP" Dst-alias="sip:bd4de6b0-8f1e-c91c-215f-a84178316e91@10.113.50.157" Call-serial-number="60475a44-31c1-446c-bfc6-309f5f9a27db" Tag="1b86cd87-52b2-41f0-bab2-41230bdb3465" Detail="searchtype:INVITE" Level="1" UTCTime="2015-05-19 08:02:49,716"
2015-05-19T11:02:46+03:00tvcs: Event="Call Rejected" Service="SIP" Src-ip="172.16.142.41" Src-port="5060" Src-alias-type="SIP" Src-alias="sip:1111@172.16.142.41" Dst-alias-type="SIP" Dst-alias="sip:bd4de6b0-8f1e-c91c-215f-a84178316e91@10.113.50.157:51630;transport\=tls" Call-serial-number="45b1c960-71c6-4e5f-968e-510cd880305d" Tag="1b86cd87-52b2-41f0-bab2-41230bdb3465" Detail="Request Terminated" Protocol="TCP" Response-code="487" Level="1" UTCTime="2015-05-19 08:02:46,483"
2015-05-19T11:02:46+03:00tvcs: Event="Search Cancelled" Service="SIP" Src-alias-type="SIP" Src-alias="1111@172.16.142.41" Dst-alias-type="SIP" Dst-alias="sip:bd4de6b0-8f1e-c91c-215f-a84178316e91@10.113.50.157:51630;transport\=tls" Call-serial-number="45b1c960-71c6-4e5f-968e-510cd880305d" Tag="1b86cd87-52b2-41f0-bab2-41230bdb3465" Detail="searchtype:INVITE" Level="1" UTCTime="2015-05-19 08:02:46,483"
2015-05-19T11:02:44+03:00tvcs: Event="Call Attempted" Service="SIP" Src-ip="172.16.146.36" Src-port="5073" Src-alias-type="SIP" Src-alias="sip:1111@172.16.142.41" Dst-alias-type="SIP" Dst-alias="sip:bd4de6b0-8f1e-c91c-215f-a84178316e91@10.113.50.157" Call-serial-number="60475a44-31c1-446c-bfc6-309f5f9a27db" Tag="1b86cd87-52b2-41f0-bab2-41230bdb3465" Protocol="TLS" Auth="YES" Level="1" UTCTime="2015-05-19 08:02:45,000"
2015-05-19T11:02:44+03:00tvcs: Event="Search Attempted" Service="SIP" Src-alias-type="SIP" Src-alias="1111@172.16.142.41" Dst-alias-type="SIP" Dst-alias="sip:bd4de6b0-8f1e-c91c-215f-a84178316e91@10.113.50.157" Call-serial-number="60475a44-31c1-446c-bfc6-309f5f9a27db" Tag="1b86cd87-52b2-41f0-bab2-41230bdb3465" Detail="searchtype:INVITE" Level="1" UTCTime="2015-05-19 08:02:45,000"
2015-05-19T11:02:44+03:00tvcs: Event="Call Attempted" Service="SIP" Src-ip="172.16.142.41" Src-port="5060" Src-alias-type="SIP" Src-alias="sip:1111@172.16.142.41" Dst-alias-type="SIP" Dst-alias="sip:bd4de6b0-8f1e-c91c-215f-a84178316e91@10.113.50.157:51630;transport\=tls" Call-serial-number="45b1c960-71c6-4e5f-968e-510cd880305d" Tag="1b86cd87-52b2-41f0-bab2-41230bdb3465" Protocol="TCP" Auth="YES" Level="1" UTCTime="2015-05-19 08:02:44,975"
2015-05-19T11:02:44+03:00tvcs: Event="Search Attempted" Service="SIP" Src-alias-type="SIP" Src-alias="1111@172.16.142.41" Dst-alias-type="SIP" Dst-alias="sip:bd4de6b0-8f1e-c91c-215f-a84178316e91@10.113.50.157:51630;transport\=tls" Call-serial-number="45b1c960-71c6-4e5f-968e-510cd880305d" Tag="1b86cd87-52b2-41f0-bab2-41230bdb3465" Detail="searchtype:INVITE" Level="1" UTCTime="2015-05-19 08:02:44,975
Call details from the Expressway-C:
Call details
Call information
StateDisconnected
Start time2015-05-19 11:02:44
End time2015-05-19 11:02:46
Duration2 seconds
Tag1b86cd87-52b2-41f0-bab2-41230bdb3465
Serial number45b1c960-71c6-4e5f-968e-510cd880305d
TypeVideo
Bandwidth
Requested384 kbps
Allocated384 kbps
RouteCEtcp-172.16.142.41 -> Zone002ToTraversalSZ -> TraversalSubZone -> Zone004ToTraversalSZ -> Unified Communication Manager Zone
Leg 1
Bandwidth nodeCEtcp-172.16.142.41
Source alias 1sip:1111@172.16.142.41 (Url)
Target alias 1sip:bd4de6b0-8f1e-c91c-215f-a84178316e91@10.113.50.157:51630;transport=tls (Url)
ProtocolSIP
Address172.16.142.41:5060
TransportTCP
ReasonRequest Terminated
Cause487
Leg 2
Bandwidth nodeUnified Communication Manager Zone
Target alias 1sip:1411@172.16.142.41 (Url)
ProtocolSIP
AddressPUBLIC_IP_EXPRESSWAY-E:7002
TransportTLS
Leg 3
ProtocolSIP
Address172.16.146.36:5071
TransportTLS
Encryption typeNone
Session 1
StatusReplaced
Media routedTrue
Call routedTrue
Participant 1Leg 1
Participant 2Leg 2
Bandwidth allocated0 kbps
Bandwidth requested0 kbps
Session 2
StatusCancelled
Media routedFalse
Call routedTrue
Participant 1Leg 1
Participant 2Leg 3
Bandwidth allocated384 kbps
Bandwidth requested384 kbps
Call details from Expressway-E:
Call details
Call information
StateDisconnected
Start time2015-05-19 11:02:45
End time2015-05-19 11:02:49
Duration4 seconds
Serial number0b3ee2f9-6655-41f7-a817-13e2414ab77b
TypeVideo
Bandwidth
Requested384 kbps
Allocated384 kbps
RouteUnified Communication Manager Zone -> Zone003ToTraversalSZ -> TraversalSubZone -> CollaborationEdgeZToTraversalSZ -> CollaborationEdgeZone
Leg 1
Target alias 1sip:bd4de6b0-8f1e-c91c-215f-a84178316e91@10.113.50.157 (Url)
ProtocolSIP
AddressPUBLIC_IP_EXPRESSWAY-E:28208
TransportTLS
Encryption typeNone
Cause487
Leg 2
Bandwidth nodeCollaborationEdgeZone
ProtocolSIP
Address146.185.36.95:48795
TransportTLS
Encryption typeNone
Session 1
StatusCancelled
Media routedTrue
Call routedTrue
Participant 1Leg 1
Participant 2Leg 2
I appreciate your help with this.
Jad
8 Replies 8
paulonwude
Hi Jad,
Did you ever solve this?
--Paul
was there a solution for this issue. I have the same problem on an MRA deployment with 11.5 CUCM
Did anyone ever find a solution?
We are having the same Expressway MRA calling issue with CUCM version 11. Seeing the Response Code 487. Did anyone ever figure this out?
Thanks. Jordan
Same here, did anyone ever find the answer?
Luis Rodriguez
Hi!
I have the same issue happening on my MRA deployment did you figured out how to solve it?
Hi, Did anyone solve the problem ?
jefferymitchell
Did anyone find a resolution for this issue? I have a few users not all that can receive inbound calls and make outbound calls when connected to the VPN. These same users can make outbound calls but can't receive inbound calls when calls route through the internet. I get the 487 request terminated error message.
