Camera serial number check?
Cisco User
Can I have the serial numbers of the cameras in TMS ?
Best regards
Ravi Yadav
Level 4
Level 4
No that would be showing when taking a CLI access on codec
xstatus camera
or looking on the camera physically.
Ravi Kr.
amehla
yes, you can check the SN of camera connected to codec in the TMS.
select the codec whose camera SN you need to know.
go to settings>extended settings
open system status, inside system status , you will be able to check all system xstatus along with camera SN.
thanks for the info Amit
Cisco User
Hi Amit;
thanks for answer but. I want to see all devices because more than the number of devices.in this way it will be difficult
