05-17-2013 12:29 PM - edited 03-18-2019 01:08 AM
Was wondering what network effects would occur from enabling IP RGC4821 Mode on the VCS? Does this pose a security risk? Would any other changes need to be made on VCS for normal communication? Currently firwall is giving an error to PMTU-D. Call connects but no video is sent. It only works if call is forced to SIP.
05-17-2013 12:31 PM
RFC 4821 is what I want to enable.
05-17-2013 05:32 PM
Hi Michael,
Please refer to the following document on PMTUD https://supportforums.cisco.com/docs/DOC-23594
HTH.
BR, Mahesh Adithiyha
05-18-2013 12:20 AM
Hi Michael,
RFC4821 provide mechanism to detect unreachable UDP port, for if there is link congestion.
It uses ICMP Type 3 code 3 -Destination not reachable when a UDP port is blocked.
If there is congestion on link, far-end or intermidiate devices does not support the MTU as present value, it will send ICMP type 3 code 4 fragmentation needed.
If DF bit (dont fragmnet bit) is set in IP header flag, it will be informed as well.It does not pose any security threat from what i know and it will not affect the normal communication of the VCS.
Hope it helps
Sagar
05-19-2013 02:37 AM
what is your end goal as a result of enabling RFC4821?
