can hear but unable to talk
vinh.nguyen
I have setup a dial-peer to connect my call. I was able to connect to the other end(outbound call). the problem I'm facing is that for some reason, the other end can't hear anything from me, but I can hear from the other end.
Thanks.
8 Replies 8
amitkumarp
Level 4
Level 4
Well you're facing the One way voice issue. Have youu tried pinging from your end to the end where you're calling??
To talk and hear, both ends must be pinging each other. Here I am attaching the document to troubleshoot the one way voice issue.
Hope this helps you.
Amit.
I just looked into my system and saw that "show clock" is showing incorrect date. The document you gave me did mention incorrect "clock" could be the cause for one way voice issue.
What I wanted to understand is the difference between the controller clock and the clock displayed by "show clock". Are they the same or totally different?
I searched for the difference between the clocking and got the following document. And as per this document, I guess both are different clocks.
The one they've mentioned in troubleshooting document is Controller Clock and not the one which can be seen by Show Clock command.
http://www.cisco.com/en/US/docs/routers/access/1700/1751/software/feature/guide/TDMdesc.html#wp111428
Refer to the document to understand the clocking configuration for controller.
In your case, I guess you need to check your routing i.e. if phones are in different subnets then there should be routing between them or if they're in different VLANs then inter VLAN routing need to be done, and if your router is MGCP or H.323 gateway then you need to run commands bind media source interface and bind control source interface. These are the main causes of the One voice issue.
Let me know your exact topology so that I can understand what exact problem you're facing.
Amit.
call will come in via tdm pri  -> gateway transfer call to a h323 server - > h323 server receives call and sends call back out to PSTN
my gateway and the h323 server are in different network. I dont have any control over the h323 server.
Building configuration...
Current configuration : 3982 bytes
version 12.4
hostname mygateway
boot-start-marker
no boot startup-test
boot-end-marker
enable secret 5 asdfasfasf
enable password sdfsdfs
resource-pool disable
aaa new-model
aaa group server radius test
server abcd auth-port 1812 acct-port 1813
aaa authentication login test group test
aaa authorization exec test group test
aaa accounting connection test start-stop group test
aaa session-id common
spe country usa
spe default-firmware spe-firmware-1
no ip routing
no ip cef
isdn switch-type primary-5ess
application
service test tftp://xxxx/test.tcl
service test1 tftp://xxxx/test1.tcl
paramspace english index 1
paramspace english language en
paramspace english location tftp://xxxx/
session
start test test
archive
log config
hidekeys
controller T3 7/0
framing m23
t1 1-28 controller
controller T1 7/0:1
framing esf
pri-group timeslots 1-24
controller T1 7/0:2
framing sf
controller T1 7/0:3
framing sf
controller T1 7/0:4
framing sf
controller T1 7/0:5
framing sf
controller T1 7/0:6
framing sf
controller T1 7/0:7
framing sf
controller T1 7/0:8
framing sf
controller T1 7/0:9
framing sf
controller T1 7/0:10
framing sf
controller T1 7/0:11
framing sf
controller T1 7/0:12
framing sf
controller T1 7/0:13
framing sf
controller T1 7/0:14
framing sf
controller T1 7/0:15
framing sf
controller T1 7/0:16
framing sf
controller T1 7/0:17
framing sf
controller T1 7/0:18
framing sf
controller T1 7/0:19
framing sf
controller T1 7/0:20
framing sf
controller T1 7/0:21
framing sf
controller T1 7/0:22
framing sf
controller T1 7/0:23
framing sf
controller T1 7/0:24
framing sf
controller T1 7/0:25
framing sf
controller T1 7/0:26
framing sf
controller T1 7/0:27
framing sf
controller T1 7/0:28
framing sf
gw-accounting aaa
acct-template callhistory-detail
interface GigabitEthernet0/0
ip address 123.123.123.123 255.255.255.240
no ip route-cache
duplex auto
speed auto
negotiation auto
no cdp enable
h323-gateway voip interface
h323-gateway voip bind srcaddr 123.123.123.123
interface GigabitEthernet0/1
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
negotiation auto
no cdp enable
interface Serial0/0
no ip address
no ip route-cache
shutdown
clock rate 2000000
interface Serial7/0
no ip address
no ip route-cache
shutdown
interface Serial0/1
no ip address
no ip route-cache
shutdown
clock rate 2000000
no cdp enable
interface Serial7/0:1:23
no ip address
encapsulation hdlc
isdn incoming-voice modem
no cdp enable
interface Group-Async0
no ip address
encapsulation slip
no ip route-cache
no group-range
interface Group-Async1
no ip address
encapsulation slip
group-range 1/00 6/107
ip forward-protocol nd
no ip http server
radius-server host srv auth-port 1812 acct-port 1812
radius-server host srv.53 auth-port 1812 acct-port 1813
radius-server key testing123
radius-server vsa send accounting
radius-server vsa send authentication
control-plane
voice-port 7/0:1:D
bearer-cap Speech
mgcp
dial-peer voice 1 pots
service test1
incoming called-number 832
direct-inward-dial
port 7/0:1:D
dial-peer voice 2 voip
destination-pattern 84.........$
session target ipv4:h323srv
tech-prefix 17116
dial-peer search type voice data
ss7 mtp2-variant Bellcore 0
ss7 mtp2-variant Bellcore 1
ss7 mtp2-variant Bellcore 2
ss7 mtp2-variant Bellcore 3
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password fdgdfgdf
line 1/00 6/107
modem InOut
scheduler allocate 10000 400
no process cpu extended
no process cpu autoprofile hog
end
Hi Vinh,
you haven't told me if you are able to ping to the other end where you're calling.
Amit.
I tried to ping but wasn't able to. I think they just disable "ping" on their system.
If you're not able to ping then you need to check the routing. And get a confirmation from them if they have really disabled the ping.
As far as I know, you at least should be able to ping.
Amit.
Yes I verified with the provider. They disabled imcp.
I'm really at lost as what is needed to be done. I had debug voip rtp. But couldn't get much out of it.
Any advices or pointers would be greatly appreciated.
