12-13-2013 09:46 AM - edited 03-18-2019 02:18 AM
I have a brand new MX200 and would like to connect the 8" Touch remote via a LAN connection rather than a direct cabled connection to the MX200
I previously understood that the MX series could do LAN connected Touch tremotes like the C Series... apparently not
Can someone confirm this.... Is there an software enhancement request in place for LAN connect.
This is frustrating,,, essentially the same 8"Touch has multiple part number and works different on the EX, MX and C Series... a bit of consistency
would be nice. the MX series is desugned for Conf rooms and should have the 8" remote via LAN capability...
Can I use the power brick and 8" touch from a C Series and make it work on an MX200?
12-13-2013 11:49 AM
At least regards EX and C version its the shorter cable length for the ex90,
I would not like to have 7,5m cable on my desk, not sure whats the difference with the MX version.
It might have been easier if it would have been either a simple POE device or
the cables would have been more modular.
The ex also have a handset , the mx a long cable (not sure if you could
hook up a handset there).
The intention of a MX200 is to use it easy with plug and play in a small to medium size room,
there also the approach with the long cable and a direct physical connection incl power to
to the codec makes sense as well.
I did not try it and its on your own risk, but I could picture that the MX version works with
the power injector, maybe you hav to disable the secondary port.
I could also picture that the C Series version would work on it.
If you tried it and it did not work then it might not work. If you do not get a better answer,
talk to your Cisco partner or contact, maybe they can say something.
If you get additional info, please let us know here as well.
Please remember to rate helpful responses and identify helpful or correct answers.
12-29-2013 05:24 PM
There's mixed responses in the forums about whether you CAN use a LAN connected touch panel or NOT.
Best bet is to give it a try and see how you go. Note: It may not be a "supported" solution.
Wayne
Please remember to rate resposnes and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
