You can acquire the same gateway from two different clusters using H323 and SIP, but not using MGCP.
That said, if one cluster acquires the router using MGCP the other can acquire it using H323 or SIP, but the H323 or SIP process could not use resources (like a PRI) that is managed by MGCP.
Maren
