Cannot add end point to TMSXE
When I add the end point in TMSXE, and enter the smtp address, the system tells me the smtp address is incorrect. It seems to fill it out on its own, no matter what I put in there according to the log file. I enter M-CR-CRPMUTCT@pmusa.net and in the log it states M-CR-CRPMUTCT@altria.com.
What is going on? This is the second time its happened.
Zac Colton
You need to play close attention to what you are typing in, and where you are putting these values.
