CAS/SIP configuration
paulavts1
Hi All,
Using the cisco router (2900 series) as an SIP to E&M gateway. On one side we have a SIP device and on the other side of the gateway we have an E&M device.
When the E&M device terminates a call the gateway should issue a SIP BYE message to the other party. This does not happen.
Call termination, when done from the SIP device, is fine.
The IOS runniung on the 2911 router is 15.0<1>M8.
Can you please assist ?, I have added the startup-config file.
Thanks in advance .
paolo bevilacqua
Can you take "debug vpm signal" and "debug ccsip message" for the case in question?
Please do no enable any other debug, and do not use attachmetns.
