03-17-2018 04:54 AM - edited 03-18-2019 01:58 PM
Is it possible to configure TelePresence endpoints such as DX and SX to use the same personal phone book as 8841 or 8845 endpoints?
If a user logs in using extension mobility to a 8841 or 8845 they can then log into there personal Directory. When they log into a DX or SX they can only access the corporate directory.
I notice in CUCM that there is an "Alternative Phonebook Server address" under Device - Phone for CE devices. I have tried a couple of different URLs in this field but none of them work. It does however stop the DX/SX displaying the corporate directory, so it's doing something.
Has anyone had any success configuring this?
Many Thanks
Solved! Go to Solution.
03-18-2018 04:44 AM
I wouldn’t bet on it. PAB hasn’t been enhanced since CUCM ran on Windows and that was ages ago. I suggest using favorites on CE code endpoints as the nearest equivalent. Another option would be Jabber in deskphone control mode with Custom Contacts. These allow a user to create buddy list entries on their Jabber client that work for click-to-dial only, not IM&P.
03-17-2018 03:15 PM
03-18-2018 01:28 AM
03-18-2018 04:44 AM
