Changing username on a Tandberg Edge95 MXP
jwill2271
I need to change the username from tandberg to admin.  This unit is remote and I will use SSH.  I am not sure what the command line is.
Jens Didriksen
Level 9
Level 9
You don't need a username to log in to MXP endpoints, when using SSH just hit "enter" when prompted for username, you will then be prompted for the password.
Same goes for accessing the web gui; only password is required.
I do recall some browsers required you to enter a username, but this was a browser, not a system requirement and you could enter whatever you liked, it just needed something in the username field.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Jens Didriksen
Level 9
Level 9
/jens
