Cisco 2951 Telephony-Service Help
jwood1650
I have a 2951 router with 2 7960 phones and a 3550 switch.  I can't get my phones to see the router, and I'm kinda stuck.  Can any one help me pleae?
here is my config:
CallManager#show run
Building configuration...
Current configuration : 3466 bytes
version 12.4
hostname CallManager
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp pool VOICE/DATA
   network 10.0.50.0 255.255.255.0
crypto pki trustpoint TP-self-signed-2215009052
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2215009052
revocation-check none
rsakeypair TP-self-signed-2215009052
crypto pki certificate chain TP-self-signed-2215009052
certificate self-signed 01
  30820243 308201AC A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32323135 30303930 3532301E 170D3032 30333031 30333032
  35345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 32313530
  30393035 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B100 E333437B 44D0EC60 8FADE1A0 89D3ADBC CDE13BD5 623B5205 75493AFB
  C0D8BF0F 8D9129F1 5DE54189 C182498F 531FE400 AEA816C6 F6A7FCF0 447636BB
  79B90C31 51B2879A 84489D5D 889DA761 835E8501 C9D86C3F 453214A2 A8EEA53C
  C0244A31 703DA1F7 CA61AAAE A9BD3AED A1910AB4 98F24607 18208372 6E12F2B1
  85450203 010001A3 6B306930 0F060355 1D130101 FF040530 030101FF 30160603
  551D1104 0F300D82 0B43616C 6C4D616E 61676572 301F0603 551D2304 18301680
  14490111 E89DCDAD EBB061C6 84597CC0 58E8CFCE 30301D06 03551D0E 04160414
  490111E8 9DCDADEB B061C684 597CC058 E8CFCE30 300D0609 2A864886 F70D0101
  04050003 8181005E 1836583B 9DF893A4 CD9EBEDC 9E047C45 1DBEDF52 1DBEA712
  0D1902D5 DD2EF6BC 9D9C512B 5480C0F8 4797CF4E 18F1D0EF CB8C616E 6521F100
  D5694172 28A7E76E 86F85D2A 03D6C9AA 0AA48E6B 069B734F 1493243D 8BADDFE6
  7D72D50E 5DDABABC 3F06A53B CDF7F45E 1B401424 A178F941 51AE7052 78DAA63E
  694C7DE2 8C9D64
        quit
username woodjl password 0 henry999 privilege 15
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 10.0.50.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
encapsulation frame-relay
no fair-queue
interface Serial0/0.21 point-to-point
ip address 10.1.12.2 255.255.255.0
snmp trap link-status
frame-relay interface-dlci 201
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
tftp-server flash:P00308000400.bin
tftp-server flash:P00308000400.loads
tftp-server flash:P00308000400.sb2
tftp-server flash:P00308000400.sbn
control-plane
voice-port 1/0/0
ring cadence pattern01
signal groundStart
cptone GB
voice-port 1/0/1
signal groundStart
voice-port 1/1/0
voice-port 1/1/1
gatekeeper
shutdown
telephony-service
max-ephones 24
max-dn 48
ip source-address 10.0.50.5 port 2000
max-conferences 4 gain -6
transfer-system full-consult
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
login
ntp server 64.209.210.20
end
7 Replies 7
paolo bevilacqua
You are missing most configuration.
Follow all the required steps per documentation.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
jwood1650
Thanks....got it working. ..kinda..I'm having trouble with making and receiving calls from the landline connected via FXO 1/1/0. Sometimes it goes through and sometimes it gives a busy signal. I can't call into the system (cell phone to landl I'm landline) rings onces and hangs uo...any ideas... thanks.
Here is my config:
urrent configuration : 5145 bytes
version 12.4
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
ip cef
   option 150 ip 10.0.50.1
   default-router 10.0.50.1
trunk group  OUT
voice service voip
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class cause-code 1
no-circuit
  69666963 6174652D 32323135 30303930 3532301E 170D3032 30333031 30333537
  33325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  04050003 8181004D D36BE2A1 BE96122F 1E64D67E 953F267F 39A2914B 8D5E6346
  932497B8 2343EF09 EC990B46 B447B035 7DDA5390 A8BAB7DC DC43C421 ED2A5306
  ABB14F29 E92FA791 C46929A0 5D65568B 2CEDFED7 BFC375A5 DA0C063E 563AF7DA
  3D7E6C5A 5A5480E9 827CC50B 6C6A889A 2831F786 BB00BCDB 594D10EE 671ADFC2
  7C30E0DA 357518
        quit
archive
log config
  hidekeys
duplex auto
speed auto
interface Serial0/0
no ip address
no fair-queue
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
ip http server
ip http path flash:gui
control-plane
voice-port 1/0/0
signal groundStart
cptone GB
voice-port 1/0/1
signal groundStart
voice-port 1/1/0
trunk-group OUT
ring number 10
signal groundStart
cptone GB
connection plar opx XXXXXXXXXX  <--------that is my landline #
description Office Line
voice-port 1/1/1
signal groundStart
dial-peer voice 100 pots
description Local Calls
destination-pattern 50
port 1/1/0
dial-peer voice 1001 pots
trunkgroup OUT
description Long Distance
destination-pattern 1[2-9]..[2-9]......
forward-digits all
dial-peer voice 1002 pots
trunkgroup OUT
destination-pattern .T
forward-digits 7
dial-peer voice 1003 pots
description International
destination-pattern 011T
port 1/1/0
gatekeeper
shutdown
telephony-service
load 7960-7940 P00308000400
max-ephones 24
max-dn 48
timeouts interdigit 2
web admin system name admin secret 5 $1$wMrx$WGyz/gL0UlSrWOhB6IBuz0
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1
number 88
label Lab
description Network Lab Phone
name Lab
ephone-dn  2
number 55
label Office Desk
description Jonathan's Desk
name Office Desk
ephone  1
device-security-mode none
description Lab Phone
mac-address 0013.80DF.7F34
type 7960
button  1:1 2:2
ephone  2
description Office Desk
mac-address 0011.20BA.F7B8
type 7960
button  1:1 2:2
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
line vty 5 15
login
end
Sent from Cisco Technical Support Android App
Must use signal loopstart, not groundstart.
Please remember to rate useful posts clicking on the stars below.
Made the change, but still the same issue.  When I call in it either rings once and hangs up or rings once and give me a new dial tone...either one will not ring through to the IP phones.  Also when I try to make an an outbound call sometimes it works and sometimes it just gives me a busy tone.....  Not sure what is wrong or how to fix it.
Any and all help is much apperciated.
Current configuration : 5124 bytes
version 12.4
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
ip cef
trunk group  OUT
voice service voip
voice class codec 1
no-circuit
  69666963 6174652D 32323135 30303930 3532301E 170D3032 30333031 30353233
  34315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  04050003 81810082 16CF555B 278B172B FDC6A5D1 97CD3606 DF0AB3EA 9E174AA5
  3A2BDA4B E080B2FF D6BAA4DE 20A5BFB0 7398FB9E 65F1DFFC 5BD34ACA C7CCB434
  846CEDD9 676A4E11 A33FE3D3 BAC0675B 2F406966 8D5FF5BC 9C83AEB9 77792CE6
  893551D1 6AF4E1C4 0DC54837 07ED14A6 D8A2F576 77C335D8 476339C7 A8F19D00
  C39E3429 80B429
        quit
archive
log config
  hidekeys
duplex auto
speed auto
interface Serial0/0
no ip address
no fair-queue
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
ip http server
control-plane
voice-port 1/0/0
signal groundStart
cptone GB
voice-port 1/0/1
signal groundStart
voice-port 1/1/0
trunk-group OUT
ring number 10
no battery-reversal
cptone GB
connection plar opx 7025861325
voice-port 1/1/1
port 1/1/0
trunkgroup OUT
forward-digits all
trunkgroup OUT
forward-digits 7
port 1/1/0
gatekeeper
shutdown
telephony-service
max-ephones 24
max-dn 48
ephone-dn  1
number 88
label Lab
name Lab
ephone-dn  2
number 55
label Office Desk
name Office Desk
ephone  1
type 7960
button  1:1 2:2
ephone  2
type 7960
button  1:1 2:2
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
line vty 5 15
login
end
Would need to see "debug vpm traces", etc.
The "connection plar opx xxxxxxx" line needs to be a number on your system (for example a hunt pilot or directory number). Try changing this line to a different number eg. 88 or 55 and it should ring on one of your internal phones.
jwood1650
Does the rest of the config look ok? Sorry new to this and had to use several different tutorials.
