Cisco C40 automatically unregister with CUCM 8.6.2
rajesh.kumar
Level 4
Level 4
I have Cisco C40 connected to CUCM 8.6.2.
First time it is registered with CUCM and I was able to make call to C40 from other phone.
Then, C40 automatically unregisterd from CUCM and it is not registering with CUCM now.
I have added C40 via, Device->Phone->Add new->then Selected Teleprecense C40
C40 SW version is : 5.1.5.297625
I have attached C40 and CUCM screen shot. It shows unregistered, this proves C40 registerd at least once.
I was able to make and receive call with C40 for couple of minutes. Afterwards unregistered automatically and now,
error message is status : Failed
Pls. suggest
Rgds
Rajesh
Hi Rajesh,
please makes below changes in your SIP settings:
change SIP profile 1 Type to Cisco as this is native registration and default transport to TCP
*c xConfiguration SIP Profile 1 URI: "1345@172.31.131.10
*c xConfiguration SIP Profile 1 DisplayName: ""
*c xConfiguration SIP Profile 1 DefaultTransport: TCP
*c xConfiguration SIP Profile 1 TlsVerify: Off
*c xConfiguration SIP Profile 1 Type: Cisco
*c xConfiguration SIP Profile 1 Outbound: Off
*c xConfiguration SIP Profile 1 Proxy 1 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 1 Address: "172.31.131.10"
*c xConfiguration SIP Profile 1 Proxy 2 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 2 Address: ""
*c xConfiguration SIP Profile 1 Proxy 3 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 3 Address: ""
*c xConfiguration SIP Profile 1 Proxy 4 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 4 Address: ""
*c xConfiguration SIP Profile 1 Authentication 1 LoginName: ""
*c xConfiguration SIP Profile 1 Authentication 1 Password: ""
8 Replies 8
prarawat
Hi Rajesh,
Please delete the Profile from the CUCM and follow this document to register the device again to the CUCM :
http://www.mediafire.com/view/?i0oudfaz562m9u1
Please try this and hopefully it will register the device with the CUCM.
In order to check whether the CUCM is reachable from the C40, please SSH into the C40 codec and use this command to check the connectivity: systemtools network ping
Prashant Rawat
Dear Prashant
Thanks a lot, I have added using similar procedure, except User and C40 association.
C40 status was showing registerd for few minutes, I was able to make call, after few minutes it unregistered and then not registering with CUCM at all....! (Thanks to Cisco for this new feature..!)
Is that mandatory, add diagest user ? I have already EX90 registered without any digest user account.
Rgds
Rajesh
amehla
Hi Rajesh,
you dont need to have digest user account as this is a native registration.
to check this issue in detail , can you provide xstatus sip and xconfig sip from unit. you can capture them from SSH or telent.
Hi Rajesh,
Can you check whether there is any connectivity between CUCM and codec ?
In order to check whether the CUCM is reachable from the C40, please SSH  into the C40 codec and use this command to check the connectivity:  systemtools network ping . Please try this command when the device is unregistered with the CUCM.
Prashant Rawat
systemtools network ping 172.31.131.10
ping: 172.31.131.10 (172.31.131.10), 3 packets, timeout 2 seconds.
3 packets transmitted, 3 received, 0% packet loss, avg rtt 0.92 ms
xstatus and cxonfig sip output
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.04.07 16:15:37 =~=~=~=~=~=~=~=~=~=~=~=
xstatus
*s Audio Microphones Mute: Off
*s Audio Volume: 70
*s Audio Input LocalInput 1 Name: "Microphone"
*s Audio Input LocalInput 1 MixerMode: "GainShared"
*s Audio Input LocalInput 1 Mute: "Off"
*s Audio Input LocalInput 1 Channels: 1
*s Audio Input LocalInput 1 AGC: "On"
*s Audio Input LocalInput 1 Connector: "Microphone.1"
*s Audio Input LocalInput 1 Connector: "Microphone.2"
*s Audio Input LocalInput 2 Name: "PC input"
*s Audio Input LocalInput 2 MixerMode: "Fixed"
*s Audio Input LocalInput 2 Mute: "Off"
*s Audio Input LocalInput 2 Channels: 2
*s Audio Input LocalInput 2 AGC: "Off"
*s Audio Input LocalInput 2 Connector: "Line.1"
*s Audio Input LocalInput 2 Connector: "Line.2"
*s Audio Input LocalInput 3 Name: "HDMI input"
*s Audio Input LocalInput 3 MixerMode: "Fixed"
*s Audio Input LocalInput 3 Mute: "Off"
*s Audio Input LocalInput 3 Channels: 2
*s Audio Input LocalInput 3 AGC: "Off"
*s Audio Input LocalInput 3 Connector: "HDMI.2"
*s Audio Output LocalOutput 4 Name: "Loudspeaker"
*s Audio Output LocalOutput 4 Loudspeaker: "On"
*s Audio Output LocalOutput 4 Channels: 2
*s Audio Output LocalOutput 4 Connector: "Line.1"
*s Audio Output LocalOutput 4 Connector: "Line.2"
*s Audio Output LocalOutput 4 Connector: "HDMI.1"
*s Audio Output LocalOutput 4 Input 2 Gain: 0
*s Audio Output LocalOutput 4 Input 3 Gain: 0
*s Audio Output LocalOutput 5 Name: "Recorder"
*s Audio Output LocalOutput 5 Loudspeaker: "Off"
*s Audio Output LocalOutput 5 Channels: 2
*s Audio Output LocalOutput 5 Input 1 Gain: 0
*s Audio Module 0 Type: Unknown
*s Audio Module 0 SoftwareID: ""
*s Audio Module 0 HardwareID: ""
*s Audio Module 0 Connector: ""
*s Camera 1 Connected: False
*s Camera 1 HardwareID: ""
*s Camera 1 Manufacturer: ""
*s Camera 1 Model: ""
*s Camera 1 SoftwareID: ""
*s Camera 1 SerialNumber: ""
*s Camera 1 IpAddress: ""
*s Camera 1 MacAddress: ""
*s Camera 1 Position Pan: 0
*s Camera 1 Position Tilt: 0
*s Camera 1 Position Zoom: 16
*s Camera 1 Position Focus: 4000
*s Camera 1 Capabilities Options: ""
*s Camera 1 Flip: "Off"
*s Camera 2 Connected: False
*s Camera 2 HardwareID: ""
*s Camera 2 Manufacturer: ""
*s Camera 2 Model: ""
*s Camera 2 SoftwareID: ""
*s Camera 2 SerialNumber: ""
*s Camera 2 IpAddress: ""
*s Camera 2 MacAddress: ""
*s Camera 2 Position Pan: 0
*s Camera 2 Position Tilt: 0
*s Camera 2 Position Zoom: 16
*s Camera 2 Position Focus: 4000
*s Camera 2 Capabilities Options: ""
*s Camera 2 Flip: "Off"
*s Camera 3 Connected: False
*s Camera 3 HardwareID: ""
*s Camera 3 Manufacturer: ""
*s Camera 3 Model: ""
*s Camera 3 SoftwareID: ""
*s Camera 3 SerialNumber: ""
*s Camera 3 IpAddress: ""
*s Camera 3 MacAddress: ""
*s Camera 3 Position Pan: 0
*s Camera 3 Position Tilt: 0
*s Camera 3 Position Zoom: 16
*s Camera 3 Position Focus: 4000
*s Camera 3 Capabilities Options: ""
*s Camera 3 Flip: "Off"
*s Camera 4 Connected: False
*s Camera 4 HardwareID: ""
*s Camera 4 Manufacturer: ""
*s Camera 4 Model: ""
*s Camera 4 SoftwareID: ""
*s Camera 4 SerialNumber: ""
*s Camera 4 IpAddress: ""
*s Camera 4 MacAddress: ""
*s Camera 4 Position Pan: 0
*s Camera 4 Position Tilt: 0
*s Camera 4 Position Zoom: 16
*s Camera 4 Position Focus: 4000
*s Camera 4 Capabilities Options: ""
*s Camera 4 Flip: "Off"
*s Camera 5 Connected: False
*s Camera 5 HardwareID: ""
*s Camera 5 Manufacturer: ""
*s Camera 5 Model: ""
*s Camera 5 SoftwareID: ""
*s Camera 5 SerialNumber: ""
*s Camera 5 IpAddress: ""
*s Camera 5 MacAddress: ""
*s Camera 5 Position Pan: 0
*s Camera 5 Position Tilt: 0
*s Camera 5 Position Zoom: 16
*s Camera 5 Position Focus: 4000
*s Camera 5 Capabilities Options: ""
*s Camera 5 Flip: "Off"
*s Camera 6 Connected: False
*s Camera 6 HardwareID: ""
*s Camera 6 Manufacturer: ""
*s Camera 6 Model: ""
*s Camera 6 SoftwareID: ""
*s Camera 6 SerialNumber: ""
*s Camera 6 IpAddress: ""
*s Camera 6 MacAddress: ""
*s Camera 6 Position Pan: 0
*s Camera 6 Position Tilt: 0
*s Camera 6 Position Zoom: 16
*s Camera 6 Position Focus: 4000
*s Camera 6 Capabilities Options: ""
*s Camera 6 Flip: "Off"
*s Camera 7 Connected: False
*s Camera 7 HardwareID: ""
*s Camera 7 Manufacturer: ""
*s Camera 7 Model: ""
*s Camera 7 SoftwareID: ""
*s Camera 7 SerialNumber: ""
*s Camera 7 IpAddress: ""
*s Camera 7 MacAddress: ""
*s Camera 7 Position Pan: 0
*s Camera 7 Position Tilt: 0
*s Camera 7 Position Zoom: 16
*s Camera 7 Position Focus: 4000
*s Camera 7 Capabilities Options: ""
*s Camera 7 Flip: "Off"
*s Conference Presentation Mode: Off
*s Conference Presentation Protocol: ""
*s Conference Presentation Resolution Height: 0
*s Conference Presentation Resolution Width: 0
*s Conference Presentation SiteId: 0
*s Conference Presentation LocalSource: 0
*s Conference Multipoint Mode: "MultiSite"
*s Conference DoNotDisturb: Inactive
*s Experimental Audio Input Connectors Microphone 1 Activity: False
*s Experimental Audio Input Connectors Microphone 2 Activity: False
*s Experimental Audio Input Connectors Line 1 Activity: False
*s Experimental Audio Input Connectors Line 2 Activity: False
*s Experimental Audio Input Connectors HDMI 2 Activity: False
*s H323 Gatekeeper Status: Rejected
*s H323 Gatekeeper Address: ""
*s H323 Gatekeeper Port: 0
*s H323 Gatekeeper Reason: "Empty GK string"
*s HttpFeedback 1 URL: ""
*s HttpFeedback 1 Expression: ""
*s HttpFeedback 2 URL: ""
*s HttpFeedback 2 Expression: ""
*s HttpFeedback 3 URL: ""
*s HttpFeedback 3 Expression: ""
*s HttpFeedback 4 URL: ""
*s HttpFeedback 4 Expression: ""
*s Network 1 Ethernet MacAddress: "00:50:60:0D:48:76"
*s Network 1 Ethernet Speed: "1000full"
*s Network 1 IPv4 Address: "172.31.102.193"
*s Network 1 IPv4 SubnetMask: "255.255.255.0"
*s Network 1 IPv4 Gateway: "172.31.102.1"
*s Network 1 IPv4 DNS Domain Name: "mafgroup.local"
*s Network 1 IPv4 DNS Server 1 Address: "172.31.171.11"
*s Network 1 IPv4 DNS Server 2 Address: "172.31.201.11"
*s Network 1 IPv4 DNS Server 3 Address: "172.31.201.12"
*s Network 1 IPv4 DNS Server 4 Address: ""
*s Network 1 IPv4 DNS Server 5 Address: ""
*s Network 1 IPv6 Address: ""
*s Network 1 IPv6 Gateway: ""
*s Network 1 MTU: 1500
*s Network 1 VLAN Voice VlanId: "Off"
*s Preset 1 Defined: False
*s Preset 1 Type: All
*s Preset 1 Description: ""
*s Preset 2 Defined: False
*s Preset 2 Type: All
*s Preset 2 Description: ""
*s Preset 3 Defined: False
*s Preset 3 Type: All
*s Preset 3 Description: ""
*s Preset 4 Defined: False
*s Preset 4 Type: All
*s Preset 4 Description: ""
*s Preset 5 Defined: False
*s Preset 5 Type: All
*s Preset 5 Description: ""
*s Preset 6 Defined: False
*s Preset 6 Type: All
*s Preset 6 Description: ""
*s Preset 7 Defined: False
*s Preset 7 Type: All
*s Preset 7 Description: ""
*s Preset 8 Defined: False
*s Preset 8 Type: All
*s Preset 8 Description: ""
*s Preset 9 Defined: False
*s Preset 9 Type: All
*s Preset 9 Description: ""
*s Preset 10 Defined: False
*s Preset 10 Type: All
*s Preset 10 Description: ""
*s Preset 11 Defined: False
*s Preset 11 Type: All
*s Preset 11 Description: ""
*s Preset 12 Defined: False
*s Preset 12 Type: All
*s Preset 12 Description: ""
*s Preset 13 Defined: False
*s Preset 13 Type: All
*s Preset 13 Description: ""
*s Preset 14 Defined: False
*s Preset 14 Type: All
*s Preset 14 Description: ""
*s Preset 15 Defined: False
*s Preset 15 Type: All
*s Preset 15 Description: ""
*s Provisioning Status:
*s Provisioning Reason: ""
*s Provisioning Software UpgradeStatus SessionId: ""
*s Provisioning Software UpgradeStatus LastChange: ""
*s Provisioning Software UpgradeStatus Status:
*s Provisioning Software UpgradeStatus Phase:
*s Provisioning Software UpgradeStatus Message: ""
*s Provisioning Software UpgradeStatus VersionId: ""
*s Provisioning Software UpgradeStatus URL: ""
*s Provisioning Software Current VersionId: ""
*s Provisioning Software Current URL: ""
*s Provisioning Software Current CompletedAt: ""
*s Security FIPS Mode: Off
*s SIP Proxy 1 Status: Unknown
*s SIP Proxy 1 Address: "172.31.131.10"
*s SIP Proxy 1 Secure: False
*s SIP Proxy 1 Verified: False
*s SIP Registration 1 Status: Failed
*s SIP Registration 1 Reason: "Failed to send"
*s SIP Registration 1 URI: "1345@172.31.131.10"
*s SIP Registration 1 Authentication: Off
*s SIP Profile 1 Proxy 1 Status: Unknown
*s SIP Profile 1 Proxy 1 Address: "172.31.131.10"
*s SIP Profile 1 Secure: False
*s SIP Profile 1 Verified: False
*s SIP Profile 1 Authentication: Off
*s SIP Profile 1 Registration 1 Status: Failed
*s SIP Profile 1 Registration 1 Reason: "Failed to send"
*s SIP Profile 1 Registration 1 URI: "1345@172.31.131.10"
*s Standby Active: Off
*s SystemUnit ProductType: "TANDBERG Codec"
*s SystemUnit ProductId: "TANDBERG Codec C40"
*s SystemUnit ProductPlatform: "C40"
*s SystemUnit Uptime: 285
*s SystemUnit Software Application: "Endpoint"
*s SystemUnit Software Version: "TC5.1.5.297625"
*s SystemUnit Software Name: "s52000"
*s SystemUnit Software ReleaseDate: "2012-11-16"
*s SystemUnit Software MaxVideoCalls: 3
*s SystemUnit Software MaxAudioCalls: 4
*s SystemUnit Software ReleaseKey: "true"
*s SystemUnit Software OptionKeys NaturalPresenter: "true"
*s SystemUnit Software OptionKeys MultiSite: "true"
*s SystemUnit Software OptionKeys PremiumResolution: "true"
*s SystemUnit Software OptionKeys DualDisplay: "true"
*s SystemUnit Hardware Module SerialNumber: "F1AV02E00088"
*s SystemUnit Hardware Module Identifier: "C0"
*s SystemUnit Hardware Module CompatibilityLevel: "0"
*s SystemUnit Hardware MainBoard SerialNumber: "PB0589578"
*s SystemUnit Hardware MainBoard Identifier: "101681-1 [06]"
*s SystemUnit Hardware VideoBoard SerialNumber: "PB0589527"
*s SystemUnit Hardware VideoBoard Identifier: "101691-3 [15]"
*s SystemUnit Hardware BootSoftware: "U-Boot 2010.06-108"
*s SystemUnit Hardware MonitoringSoftware: "45"
*s SystemUnit Hardware Monitoring Fan 1 Status: "locked on 2746 rpm"
*s SystemUnit Hardware Monitoring Fan 2 Status: "locked on 2746 rpm"
*s SystemUnit Hardware Monitoring Fan 3 Status: "locked on 2746 rpm"
*s SystemUnit Hardware Monitoring Fan 4 Status: "locked on 2746 rpm"
*s SystemUnit Hardware Temperature: "62.5"
*s SystemUnit State System: Initialized
*s SystemUnit State MaxNumberOfCalls: 4
*s SystemUnit State MaxNumberOfActiveCalls: 4
*s SystemUnit State NumberOfActiveCalls: 0
*s SystemUnit State NumberOfSuspendedCalls: 0
*s SystemUnit State NumberOfInProgressCalls: 0
*s SystemUnit State Subsystem Application: Initialized
*s SystemUnit ContactInfo: "172.31.102.193"
*s Time ZoneOlson: Asia/Muscat
*s Video Input LastConnectedSource: 0
*s Video Input Source 1 Resolution Height: 0
*s Video Input Source 1 Resolution Width: 0
*s Video Input Source 1 Resolution RefreshRate: 0
*s Video Input Source 1 Resolution FormatType: Unknown
*s Video Input Source 1 Resolution FormatStatus: Error
*s Video Input Source 2 Resolution Height: 0
*s Video Input Source 2 Resolution Width: 0
*s Video Input Source 2 Resolution RefreshRate: 0
*s Video Input Source 2 Resolution FormatType: Unknown
*s Video Input Source 2 Resolution FormatStatus: Error
*s Video Input Source 3 Resolution Height: 0
*s Video Input Source 3 Resolution Width: 0
*s Video Input Source 3 Resolution RefreshRate: 0
*s Video Input Source 3 Resolution FormatType: Unknown
*s Video Input Source 3 Resolution FormatStatus: Error
*s Video Input HDMI 1 Connected: False
*s Video Input HDMI 1 SignalState: Unknown
*s Video Input HDMI 2 Connected: False
*s Video Input HDMI 2 SignalState: Unknown
*s Video Input DVI 3 Connected: False
*s Video Input DVI 3 SignalState: Unknown
*s Video Input Legacy 3 Connected: False
*s Video Input Legacy 3 SignalState: Unknown
*s Video Output HDMI 1 Resolution Height: 720
*s Video Output HDMI 1 Resolution Width: 1280
*s Video Output HDMI 1 Resolution RefreshRate: 60
*s Video Output DVI 2 Resolution Height: 768
*s Video Output DVI 2 Resolution Width: 1024
*s Video Output DVI 2 Resolution RefreshRate: 60
*s Video Layout PresentationView: Default
*s Video Layout Site 1 Output 1 FamilyName: "fullscreen"
*s Video Layout Site 1 Output 1 FullFamilyName: "fullscreen-local-single-camctrl"
*s Video Layout Site 1 Output 1 GraphicName: "1"
*s Video Layout Site 1 Output 1 Frame 1 PositionX: 0
*s Video Layout Site 1 Output 1 Frame 1 PositionY: 0
*s Video Layout Site 1 Output 1 Frame 1 Width: 10000
*s Video Layout Site 1 Output 1 Frame 1 Height: 10000
*s Video Layout Site 1 Output 1 Frame 1 Layer: 1
*s Video Layout Site 1 Output 1 Frame 1 VideoSourceType: "graphic"
*s Video Layout Site 1 Output 1 Frame 1 VideoSourceId: 0
*s Video Layout Site 1 Output 1 Frame 1 InputNumber: 0
*s Video Layout Site 1 Output 1 Frame 1 Filename: "/apps/posters/summersky.png"
*s Video Layout Site 1 Output 1 Frame 2 PositionX: 7084
*s Video Layout Site 1 Output 1 Frame 2 PositionY: 7154
*s Video Layout Site 1 Output 1 Frame 2 Width: 2432
*s Video Layout Site 1 Output 1 Frame 2 Height: 2432
*s Video Layout Site 1 Output 1 Frame 2 Layer: 5
*s Video Layout Site 1 Output 1 Frame 2 VideoSourceType: "site"
*s Video Layout Site 1 Output 1 Frame 2 VideoSourceId: 1
*s Video Layout Site 1 Output 1 Frame 2 InputNumber: 1
*s Video Layout Site 1 Output 1 Frame 2 Filename: ""
*s Video Layout Site 1 Output 2 FamilyName: "fullscreen"
*s Video Layout Site 1 Output 2 FullFamilyName: "fullscreen-local-single-camctrl"
*s Video Layout Site 1 Output 2 GraphicName: "1"
*s Video Layout Site 1 Output 2 Frame 1 PositionX: 0
*s Video Layout Site 1 Output 2 Frame 1 PositionY: 0
*s Video Layout Site 1 Output 2 Frame 1 Width: 10000
*s Video Layout Site 1 Output 2 Frame 1 Height: 10000
*s Video Layout Site 1 Output 2 Frame 1 Layer: 1
*s Video Layout Site 1 Output 2 Frame 1 VideoSourceType: "graphic"
*s Video Layout Site 1 Output 2 Frame 1 VideoSourceId: 0
*s Video Layout Site 1 Output 2 Frame 1 InputNumber: 0
*s Video Layout Site 1 Output 2 Frame 1 Filename: "/apps/posters/summersky.png"
*s Video Layout Site 1 Output 2 Frame 2 PositionX: 0
*s Video Layout Site 1 Output 2 Frame 2 PositionY: 0
*s Video Layout Site 1 Output 2 Frame 2 Width: 10000
*s Video Layout Site 1 Output 2 Frame 2 Height: 10000
*s Video Layout Site 1 Output 2 Frame 2 Layer: 0
*s Video Layout Site 1 Output 2 Frame 2 VideoSourceType: "site"
*s Video Layout Site 1 Output 2 Frame 2 VideoSourceId: 1
*s Video Layout Site 1 Output 2 Frame 2 InputNumber: 0
*s Video Layout Site 1 Output 2 Frame 2 Filename: ""
*s Video Layout Site 1 Output 2 Frame 3 PositionX: 7084
*s Video Layout Site 1 Output 2 Frame 3 PositionY: 6615
*s Video Layout Site 1 Output 2 Frame 3 Width: 2432
*s Video Layout Site 1 Output 2 Frame 3 Height: 1824
*s Video Layout Site 1 Output 2 Frame 3 Layer: 5
*s Video Layout Site 1 Output 2 Frame 3 VideoSourceType: "site"
*s Video Layout Site 1 Output 2 Frame 3 VideoSourceId: 1
*s Video Layout Site 1 Output 2 Frame 3 InputNumber: 1
*s Video Layout Site 1 Output 2 Frame 3 Filename: ""
** end
OK
xconfig sip
*c xConfiguration SIP Profile 1 URI: "1345@172.31.131.10"
*c xConfiguration SIP Profile 1 DefaultTransport: Auto
*c xConfiguration SIP Profile 1 Type: Standard
** end
OK
Hi Rajesh,
Dear Amit
WoW...!
Thanks for revealing secret....!
"default transport to TCP" This setting on C40 worked.
Thanks a lot for your great suppport.
Rgds
Rajesh
