02-24-2016 08:58 AM - edited 03-18-2019 05:37 AM
Hi all,
trying to get two cisco 9951 phones to work with video... calling no problem... camera self view working... so camera no problem..
enabled everything op phone profiles..... can make calls but video even not trying to show something...
what can this be?????
thanks
Solved! Go to Solution.
02-25-2016 08:17 PM
By any chance do you have the MTP required option checked on the phones??
02-26-2016 07:08 AM
02-24-2016 10:51 AM
Are they enabled for video??
Do you have enough BW in the locations for video calls?
02-24-2016 11:21 AM
Yes they are enabled in the phone and also in the settings on the ccm.... so Cisco Camera enabled and Video Capabilities enabled... also enough bandwith because it's just local....
system running on vmware and phones and vmware are connected by a switch...
something else i have may forgot to enable????
02-25-2016 11:10 AM
nobody any idea's?
02-25-2016 08:17 PM
02-26-2016 12:45 AM
Yep this is enabled on both phones...
02-26-2016 07:08 AM
Disable it and try again
02-26-2016 07:41 AM
will try It.. keep you posted :D
02-29-2016 02:20 AM
Disbale MTP required working!! Thanks mate... ;)
