Cisco CMS WebRTC
ailhan001
my cms1 address: cms1.test.local port 8443
webrtc address: join.test.local port 443
in my lab
Dns server solves for cms1.test.local and join.test.local are same  ip address which is 192.168.0.22
This is DNS Records:
C:\Users\ailhan>nslookup
Default Server: test.test.local
Address: 192.168.0.205
> cms1.test.local
Address: 192.168.0.22
> join.test.local
Addresses: 192.168.0.22
192.168.0.23
i reach cms server from: cms1.test.local:8443
for webrtc: cms1.test.local or join.test.local
but when i try to send invite message to someone cms sends cms1.test.local address. i want to send join.test local.
You're invited to my online meeting.
https://cms1.test.local/
Call ID: 786502106
Passcode: 1234
like that.
what i am doing wrong?
Jonathan Unger
Level 7
Level 7
Hi There,
There are 2 items you should check on:
  1. CMS Server Web GUI
    1. Navigate to Configuration > General "Web bridge settings"
    2. Ensure that the "Guest account client URI" field is configured for "https://join.test.local"
    3. Save
  2. TMS Server Web GUI
    1. Find the CMS server under "System > Navigator"
    2. Select "Settings" and then "Edit Settings"
    3. Ensure that the "Web Bridge" URI value is configured with "https://join.test.local"
    4. Save
Please let us know if this corrects the issue.
Thanks!
- Jon
*** Remember to rate posts as helpful and mark answers as correct if appropriate.
Jonathan Unger
Level 7
Level 7
Hi There,
    3. Save
    4. Save
Thanks!
- Jon
