Cisco Codec C40 remove wallpaper
Hi all.
In our cisco telepresence installation we've faced an interesting issue:
the cisco c40 codec admin created a custom wallpaper, somehow this wallpaper was not suitable for this codec for 100%.
after he uploaded the wallpaper on the unit - it rebooted. then we see a cyclic reboot - the unit boots, we see a cisco logo, then we see a an overlay (part of the gui) on the monitor, after that codec tries to load the wallpaper, fails and went into reboot.
Are there any ways to manually delete this wallpaper from the codec's flash without hard resetting the codec?
3 Accepted Solutions
sekuzmin
Hi Eugene,
Try to log in as admin using ssh/console and execute following command:
     xConfiguration Video Wallpaper: Summersky
Best regards,
Sergey Kuzmin
vikramdutta85
Hi Eugene,
If there is a sufficient time for you  to ssh into the codec: try below mentioned command
ssh into the codec loging as root then him command >      touch /user/noboot
(make sure that root shoukd be enabled already  for this process to work).
once youve touched the noboot file by hitting the above  command
type TSH
youll move to admin
type the command given by Sergey:
Wall paper will change
// Vikram
Hi ,
Once you are in root log in type following commnad .
rm /user/posters/wallpaper.png
This will delete wall paper.
I am more intrested to test your wall paper in my lab , can you please provide it .
Generally wall paper should not cause reboot .
hth
kind regards.
Dharmmesh
sekuzmin
Hi Eugene,
Best regards,
Sergey Kuzmin
vikramdutta85
Hi Eugene,
type TSH
youll move to admin
// Vikram
Hi ,
hth
kind regards.
Dharmmesh
Hi there!
Thanks all for your support!
I've managed to recover the codec doing the following
1. Connect the unit via RS-232 console port
2. Right after the unit boots pressed b the c to enter the u-boot
3. Then i executed the following commands
setenv othbootargs allowroot noboot interactive
setenv console ttyS0
boot
4. then I typed enter till i get the following string
Run [/etc/init.d/S80main start] (Y/n/r/s/c/?)?
Typed s here to drop to a shell
5. In the shell -
$ rm /user/posters/wallpaper.png
6. reboot
That's it - the unit is booting in a normal way with black screen instead of wallpaper and with a gui overlay.
P.S. I didn't study the logs yet but will do soon - to doublecheck that the issue was with the wallpaper.
P.P.S. I'll try to get a copy of this "evil" wallpaper to send you, Dharmesh.
https://supportforums.cisco.com/docs/DOC-29766 - this doc helped me a lot. It has all the needed information regarding "low level" troubleshooting and recovering.
BTW - this issue is described int the CSCud96920 - Codecs crashes due to using incorrect "PNG" file in wallpaper.
