Cisco EX90 Touch Panel cable Extension.
Hi Team,
We currently have EX90's setup in our environment, where the Touch panels came with the default cable length(approx 1 mtr).
We would like to have the touch panels brought and kept on the table closer to users.
Does cisco sell  these touch panels with more lengthier cables say(approx 3 mtr) or we can just purcahse the cable and replace it with the
existing one?
Krishna.
Martin Koch
There is no cable giving you the full functionality.
If you can live without the audio / handset from the touchpanel you might be able to use the
in touch screen designed for the endpoints.
That said, this is most likely not a supported setup and I would not recomend that.
What is you use case? The EX series is designed as personal desktop system.
Maybe some other system would be better for your usage?
Please remember to rate helpful responses and identify helpful or correct answers.
Wayne DeNardi
Hi Krishna,
This same question has been asked and answered many times before in these forums.
Here are some links to some of these threads:
     https://supportforums.cisco.com/thread/2098588
     https://supportforums.cisco.com/thread/2179316
     https://supportforums.cisco.com/thread/2230517
     https://communities.cisco.com/message/120210
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
