03-20-2018 05:57 AM - edited 03-18-2019 01:58 PM
Hi all,
from Cisco Jabber Guest Server :
"To minimize the effects of a disaster ,you must create a disaster recovery plan to minimize downtime and data loss. You can achieve this by using a VMware-supported disaster backup
and recovery solution or you can export the OVA files as described in this section".
Does it make sense to apply the same strategy for Cisco Expressway for example?
Did anyone try this strategy before?
thanks
03-26-2018 03:21 AM
I tested and i took note about different serial number after deploying the OVF template, to have the machine working properly i'd need a new release key generated from Cisco.
03-26-2018 03:50 AM - edited 03-26-2018 03:50 AM
I wouldnt rely on vmware backups too much,
vcse has backup and recovery, I have used it in the past and it works quite nicely,
the configuration on your expressways is quite static so a backup before you make changes will suffice.
OVA templates, you can get off the cisco download section.
03-26-2018 10:53 PM
