CMS Redundant LDAP Servers
Brian Meade
Level 7
Level 7
I'm trying to figure out the best way to do redundant LDAP Servers in CMS 2.3.
I tried creating 3 different LDAP Sources linked to 3 different LDAP Servers but this results in errors about duplicate users.
These are all the same LDAP source, just multiple servers.  I don't see any way in the API to put multiple LDAP servers under one LDAP source.
What's the correct way to do this?
See here:
Partial LDAP redundancy via DNS, requires ICMP
CSCvh65991
There is no built-in method to do periodic sync, you'd need to schedule a CRON job (or similar) externally and perform the sync.
java
if this helps, please rate
5 Replies 5
Hi @Brian Meade,
 please take a look at the following: LDAP Server Methods and CMS with LDAP.
Hope this helps,
 Marcelo Morais
it looks like I should have an LDAP Source for each LDAP Server which is what I had.  Every time I use the sync all though from webadmin, it just finds duplicates and stops since the users exist in all 3 sources.  Deleting the other 2 sources and syncing resolves the issue but I lose redundancy then.
Also, is there any way to have the server do periodic syncs automatically?
See here:
CSCvh65991
java
Jaime,
Do you have any details around the implementation of this?  It says creating multiple A-records.  Do I just want A-Records for each LDAP Server then still have 3 LDAP Servers and 3 LDAP Sources configured?
No, this is simply redundancy via DNS.
java
