6 Replies 6
Patrick Sparkman
Nice!  Have you had a chance to try it out Martin, any advice or suggestions?
Looks nice but needs documentation for configuring with VCS
Yes, good that Paul Anholt had published it, I had it as well, but I was not so sure if I was allowed to post it if Cisco did not do it :-)
Before I received it I got the ipad version running by creating my own xml file based on the movi provisioning template
which worked so I could at least provision the Ipad :-)
It needs documentation period, at least something better than what is provided.  All we have right now is the Administrators Guide, there isn't any user guides for the different use options for the app.
When posting for advise/support, I'm often asking myself which section of the forum do I post in: Jabber Clients/Jabber Video/TelePresence?    I'm seeing alot of Jabber for iPad posts related to the video side of the app in all three areas of the forums.
Didn't suprise me that the app got released with no templates available for provisioning, had to ask around to get them, but they did get them out in decent time the following day.
epicolo
Level 3
Level 3
Hi guys,
are you aware about new TMS licencing ?
LIC-JAB-MOB-n   (n=25, 100, 500, 2000)
Jabber Video (Movi) Options: Jabber Video Mobile - n User Licenses
LIC-TMS-PE-n   (n=25, 100, 500, 2000, 10000,100000)
Cisco TMS Provisioning Extension Options – n additional active licenses
I would like to know if some new license is required to be able to register Jabber for iPad on a VCS un TMS PE or is just to migrate the Legacy Mode to TMSPE (to keep using LIC-TMS-n and LIC-MOVI-n)?
Thanks for your help.
Hi Elter,
You don't need any different license for Jabber for ipad.
Also there is no separate license for PE migration. It uses the provisioning licenses. When PE migration tool is run,it will automatically detect the available provisioning licenses.
Sagar
