12-15-2015 05:28 PM - edited 03-18-2019 05:19 AM
I'm running CUCM 9.5 + MCU 3550. When I try to enable the Share desktop feature from Cisco Jabber, it's displayed for 1 second on the DX80, after that time only video is displayed.between phones. I have 2 working scenario running Cisco Jabber + C40 Codec and Cisco Jabber + Cisco Jabber.
Why Share Desktop feature is not working properly with DX80?
Thanks advance.
12-16-2015 04:31 AM
Hi Leo,
As per the Jabber for Windows user guide:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/10_6/CJAB_BK_C56DE1AB_00_cisco-jabber-106-deployment-and-installation-guide.pdf
Page 66-67:
"You can enable video desktop sharing only on software phone devices. You cannot enable video desktop sharing on desk phone devices.”
It seems that you can only share when using the CSF device.
Manish
12-16-2015 05:08 AM
Hi Manish,
Thanks for your response. I'm running Cisco Jabber as a CSF Device.
Is DX80 a deskphone device or a CODEC?
It's strange why is only working for 1 second then share desktop is dropped.
12-16-2015 05:57 AM
Hi Leo,
The DX80 is classified as an IP phone although the Product specification does say that it contains a codec, camera, display and other components. Yes, seems a bit strange if it actually works for a second and then drops. Maybe Cisco TAC can look into this to find the root cause.
Manish
12-16-2015 11:47 AM
I solved the problem, it was a Cisco Jabber issue. I installed Cisco Jabber 11.X, it worked after that.
Thanks for the help.
12-16-2015 11:54 AM
Good to know that.
Manish
