Cisco Meeting Server 3.1 Licensing
alybadara
Hello Guys,
I need you help.
For a month I couldn't activate my Cisco Meeting Server 3.1. I had a pak license and I tried it but it doesn't work then Cisco TAC converted my PAK to Smart license and I used CMM to register as recommended by CMS 3.1 but I am still stuck on this image :
6 Replies 6
b.winter
Have you added CMS in CMM?
What's the licensing status in CMM?
Hi B.Winter,
Yes already added.
You have no PMP licenses, but have you 134 lics in the last 90 days.
It's clear, that CMS is "out of compliance"
alybadara
Are PMP licenses mandatory for CMS licensing ? How can I remove these 134 lics because initially I had a traditional PAK license?
Which lics you need, depends on the setup of your CMS and how you use it. There is no yes / no answer to that.
You cannot remove the "counter" of how many meetings with PMP usage you already had in the past
OK Should I consider that my CMS license activated ?
