CISCO MEETING SERVER
abdulkarim041
Level 2
Level 2
I am going to design video conferencing solution. End points are MX800 and IX5000. My question is
If only CISCO MEETING SERVER is enough (without CUCM, Conductor and TMS) for video conference calls?
Second option is
CISCO MEETING SERVER with CUCM (without Conductor and TMS)?  Is enough for videos conference calls?
Kindly help me out to get right design
BR
Abdul Karim
Jaime Valencia
The recommended design is CUCM + CMS
Conductor is not used with CMS, it's required for vTP.
TMS, that's up to you, not required unless you want to schedule meetings.
java
if this helps, please rate
Jaime Valencia
java
Thanks Jaime,
one more questions can  we use one CMS for video conference call. without expressway or cucm. in then case whic licenecs options would be used for MX800 and IX5000.
BR
Abdul Karim
I suggest you review this
http://www.cisco.com/c/dam/en/us/td/docs/solutions/PA/midmarket/11x/video116.pdf
And also get in touch with your SE and ask further information on CMS to get up to speed with it.
java
