Cisco quad cam kit
Pedro Serras
Dear All
I need to know if the autotracking mode works in this cameras even if the codec is not in call mode because i want to record meetings local and the second camera connector is connected to a recorder . Could someone help me in this subject
regards
Pedro
Wayne DeNardi
The recorder would be a video input source if it is connected to the second camera input on the codec.
You would need to have it connected to one of the video outputs (eg as a second monitor) if you wanted it to receive the video from the codec.  You then come across other issues with connectivity and configuration, especially for local audio which by default would not be sent out one of the codec outputs, so this would not work for making a local recording without some considerable adjustments.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne DeNardi
Wayne
Tanks a lot Wayne De Nardy
My problem is only the autotracking feature because we have an audio mixer (BiamP Tesira Forte ) to manage the audio and alll the audiovisual system is controlled by an AMX system.
Anyway i did the option to integrate a SX 80 and a Sony camera and the problem is solved
Thanks a lot for your help
regards
