Cisco Room Kit Plus & SX80 API
MStout
If the Cisco Codec and the Crestron control processor are in SSH communication, would the Control Processor know the status of  the Codec when the Codec went into or came out of Standby? Thus automating the power on/off of the Displays should that be wanted, or any additional automation needs; light control, blind control, sound masking, etc…? Same with the push of the Mute button on the Touch 10 itself. Would the processor not be able to receive some status as to when the Touch 10 was telling the Codec to Mute the microphone input?
Yes, the Crestron can be programmed to look for the feedback events on the TelePresence endpoint to indicate that mics are being muted or the unit goes in to standby.  An example of the mic mute would be:
xFeedback register /Status/Audio/Microphones/Mute
You can also query the state via the xStatus API commands.  See the API Reference Guide for more details.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne
