Cisco Roomkit Plus codec usb port as external audio
JonnyMalanday
Hello everyone I just want to confirm if it is possible that I can use cisco room kit plus codec USB A/B port to use as an external speaker instead of its 3.5 mm jack audio port.
Codec Plus does support USB I/O Audio.
Here how to enable it.
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/technical-papers/cisco-collaboration-devices-audio-integration-setup-guide.pdf
Carlo
Please rate all helpful posts "The more you help the more you learn"
Carlo
JonnyMalanday
Thanks Carlo, it works for me.
Glad that helped and thanks for your rating.
Have a great rest of the week
Cheers
Carlo
