cisco spark problem
ozden ozdugun
Error
Peripheral Software Upgrade
Failed downloading software for peripheral.
Current versionce11.3.1.17.09fdf7c0b94
Wayne DeNardi
You will often get this error when you have upgraded one of the newer endpoints by using just a .pkg file.   This file only contains the software for the codec, and not the software for any of the connected peripherals.   You will need to re-upgrade the software on the device using the .cop.sha512 file that is correct for the device you are using.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
