Cisco TelePresence Conductor XC4.2 - licensing Question
marco_81
Hi all,
i'm using Conductor with uploaded option keys:
LIC-CNDTR-B30
LIC-CNDTR-C50
could anyone explain which are capabilities i can employ with these licenses in place?
regards
In order to host conferences on the TelePresence Server, it either needs screen licenses installed on it, or Mulitparty licenses (PMP or SMP) install on Conductor.
As mentioned in my previous reply, the two licenses enable you to use Conductor will up to 30 conference bridges and support up to 50 concurrent calls.
5 Replies 5
marco_81
Is the link below:
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/conductor/release_note/TelePresence-Conductor-Release-Notes-XC4-2.pdf
enough to understand the two items?
I have to be sure about capabilities offered by those two items, help will be very useful.
best regards
Your licenses needed for deploy Full Capacity Conductor .
Please see datasheet: https://www.cisco.com/c/en/us/products/collateral/conferencing/telepresence-conductor/data_sheet_c78-709046.html  and link from m.fina@hitachi-systems-cbt.com
Read about "Different Sized Deployments"
Patrick Sparkman
Those licenses are for Conductor Select (refer to Table 1 of the Conductor Data Sheet):
  • LIC-CNDTR-B30 - Conductor license, support up to 30 conference bridges.
  • LIC-CNDTR-C50 - Conductor 50 call sessions license
Thanks all for reply,
but i know that if you want to use CMR you need screen licenses or Multy party licenses and at the moment i don't have uploaded those, CMR does not work as i dial the alias configured for the conf bridge. So my question is what's the purpose of :
  • LIC-CNDTR-B30
  • LIC-CNDTR-C50
Can you confirm they are not enough to have CMR working?
thanks
