ā06-18-2017 04:08 AM - edited ā03-18-2019 01:13 PM
Hi Folks,
I am unable to get this registered.
Error:
Unknown
Here are the Logs..
2017-06-18T12:58:59.858+02:00 JLR-Nitra appl[1748]: 273.30 PROV I: [requestItem] Requesting http://10.254.129.100:6970/SEP285261f14970.cnf.xml, state=Config (full or mini)
2017-06-18T12:58:59.867+02:00 JLR-Nitra appl[1748]: 273.31 RTP I: ICMP: 10.250.2.209 type: Destination Unreachable(0), unreachable host, 10.250.2.211:44186 -> 10.254.129.100:6970
2017-06-18T12:59:00.858+02:00 JLR-Nitra appl[1748]: 274.30 PROV ERROR: [handleFailedProvRequest] reqURL=http://10.254.129.100:6970/SEP285261f14970.cnf.xml status=failed reason=Couldn't connect to server
2017-06-18T12:59:00.858+02:00 JLR-Nitra appl[1748]: 274.30 PROV I: [requestItem] Requesting http://115.114.235.86:6970/CTLSEP285261f14970.tlv, state=CTL
2017-06-18T12:59:00.867+02:00 JLR-Nitra appl[1748]: 274.31 RTP I: ICMP: 10.250.2.209 type: Destination Unreachable(0), unreachable host, 10.250.2.211:44187 -> 10.254.129.100:6970
2017-06-18T12:59:01.858+02:00 JLR-Nitra appl[1748]: 275.30 PROV I: [requestItem] Requesting http://115.114.235.86:6970/ITLSEP285261f14970.tlv, state=ITL
2017-06-18T12:59:01.858+02:00 JLR-Nitra appl[1748]: 275.30 RTP I: ICMP: 10.250.2.209 type: Destination Unreachable(0), unreachable host, 10.250.2.211:52378 -> 115.114.235.86:6970
2017-06-18T12:59:02.858+02:00 JLR-Nitra appl[1748]: 276.30 PROV I: [requestItem] Requesting http://115.114.235.86:6970/SEP285261f14970.cnf.xml, state=Config (full or mini)
2017-06-18T12:59:02.859+02:00 JLR-Nitra appl[1748]: 276.30 RTP I: ICMP: 10.250.2.209 type: Destination Unreachable(0), unreachable host, 10.250.2.211:52379 -> 115.114.235.86:6970
2017-06-18T12:59:03.858+02:00 JLR-Nitra appl[1748]: 277.30 PROV ERROR: [handleFailedProvRequest] reqURL=http://115.114.235.86:6970/SEP285261f14970.cnf.xml status=failed reason=Couldn't connect to server
2017-06-18T12:59:03.858+02:00 JLR-Nitra appl[1748]: 277.30 PROV I: CUCM Provision: Status=Failed, Reason='Couldn't connect to server'
2017-06-18T12:59:03.860+02:00 JLR-Nitra appl[1748]: 277.30 RTP I: ICMP: 10.250.2.209 type: Destination Unreachable(0), unreachable host, 10.250.2.211:52380 -> 115.114.235.86:6970
2017-06-18T12:59:36.561+02:00 JLR-Nitra appl[1748]: 310.00 SipStack I: SipTransport: NETConnectRej: failure at OS level
2017-06-18T12:59:36.562+02:00 JLR-Nitra appl[1748]: 310.01 SipStack W: SipTransport: NETConnectRej: could not connect to 115.114.235.86:5060
2017-06-18T12:59:36.562+02:00 JLR-Nitra appl[1748]: 310.01 SipStack W: [Transaction 32]: Got exception 1 (Cannot connect) from transport for 'REGISTER' request (SeqNumber=6928)
2017-06-18T12:59:36.563+02:00 JLR-Nitra appl[1748]: 310.01 RTP I: ICMP: 10.250.2.209 type: Destination Unreachable(0), unreachable host, 10.250.2.211:52931 -> 115.114.235.86:5060
2017-06-18T12:59:37.568+02:00 JLR-Nitra appl[1748]: 311.01 SipStack I: SipTransport: NETConnectRej: failure at OS level
2017-06-18T12:59:37.568+02:00 JLR-Nitra appl[1748]: 311.01 SipStack W: SipTransport: NETConnectRej: could not connect to 10.254.129.100:5060
2017-06-18T12:59:37.568+02:00 JLR-Nitra appl[1748]: 311.01 SipStack W: [Transaction 32]: Got exception 1 (Cannot connect) from transport for 'REGISTER' request (SeqNumber=6929)
2017-06-18T12:59:37.573+02:00 JLR-Nitra appl[1748]: 311.02 RTP I: ICMP: 10.250.2.209 type: Destination Unreachable(0), unreachable host, 10.250.2.211:33139 -> 10.254.129.100:5060
Can Someone please help me...???
-Vaibhav Mane
-INDIA-
Solved! Go to Solution.
ā06-18-2017 06:35 AM
I see in the log that you included:
so have you checked the obvious things, like can you ping it, is you 115 address responding to TFTP at all? is there any NAT in the path.
looks more like a connectivity related issue than anything else
cheers
cheers
ā06-26-2017 12:53 PM
Yes, you were correct.
There was Routing issue.
CUCM IP was not advertised in the VPRN/VRF of PE Router of the device.
-Vaibhav-
