03-11-2014 02:16 AM - edited 03-18-2019 02:43 AM
Hi all,
I try to disable the H264 RCDO protocol with the TMS on custom command on all the endpoints (for resolve one issue with lync2013 client)
It work for the C-SERIES EndPoint but doesn't work for the MXP EndPoint.
I have try with this command:
<configuration><conference><set configuration="H264RCDO:off"></set></conference></configuration>
Do you have ever met this issue ?
DO you know a solution?
Thanks by advance
Samy
Solved! Go to Solution.
03-11-2014 05:06 AM
What version of TMS are you currently running?
I have TMS 14.3.1, and if you search in the configuration templates in TMS under MXP you should see the configuration item to turn this off for you.
Anyhow...
<Configuration><Conference><H264RCDO>Off</H264RCDO></Conference></Configuration>
May be easier to use the configuration in TMS, but the above string should work.
Hope this helps.
VR
Patrick
03-11-2014 05:06 AM
Anyhow...
Hope this helps.
VR
Patrick
03-11-2014 05:17 AM
Hi Papettit,
Thanks for your answer!
I try and it works !
I think I got confused with XML for CSERIES...
Thanks!
Have a nice day.
Samy
