12-15-2014 02:25 AM - edited 03-18-2019 03:47 AM
I have added 4 of my Polycom HDX 8000 Series to a TMS.
The Trial TMS version being used is 13.2.2
The Polycom HDX is running 3.1.3
I wanted to understand in detail as an end user of TMS, what are the functionalities in HDX that I can expect to manage using TMS.
What I could find was,
1. Booking a conference (I believe, TMS auto dials to the added Systems when the Conference time occurs).
2. System upgrade of the HDX using the HDX .pup installer file loaded onto - C:\Program Files (x86)\TANDBERG\TMS\wwwTMS\Public\data\SOFTWARE\
3. Provisioning of the HDX systems using created Provisioning Templates in TMS.
Does this require TMSPE to be installed? TMSPE installation fails even with valid SQL Server details.
See attached. How to achieve Provisioning on HDX using TMS or TMSPE?
4. Fetching HDX Video, Call Detail Records.
5. HDX fetches the Phonebook when HDX has the TMS IP Address set as it's Global Directory Server.
Are all the above features supported? What else is supported between Polycom HDX Series and Cisco TMS.
Thanks in advance for your answer.
12-15-2014 06:59 AM
You can find more specific details on the following page, it's outdated some of the documents, but most if it still applies.
12-16-2014 06:36 PM
