Cisco VCS and Avaya Session Manager Integration
uddinabu1
Hi All,
We are replacing ISDN gateway for MCU/VCS with SIP trunk for PSTN Access using VCS x7.x and MCU5320 via Avaya Session Manager.
I would appreciate if someone provide some guidelines/user guide.
Thanks in advance
Take a look at these good guides.
https://downloads.avaya.com/css/P8/documents/100144913
https://www.devconnectprogram.com/fileMedia/download/e33b19f5-98c7-4316-9e2c-e06426bcc98a
I already used these guides as my reference in my recent project involving Cisco VCS and Avaya Session Manager integration using SIP trunk.
regards,
Acevirgil
frank.calderon
I would not go past version 8.5.3 on your VCS if you are using SIP trunks (Zones) to Avaya.  you will find 8.6 removes the feature that will allow you to limit the size of the SDP length being sent to Avaya.  Video requests will not be filtered in the zone once you upgrade to 8.6.
FYI
