11-08-2012 04:44 AM - edited 03-18-2019 12:06 AM
Hello!
Could you please tell me, when CISCO starts officially support Lync2013 - release a new software for VCS-C and documentation on integration?
The primary interest is in the possibility of transferring video between CISCO endpoints/MCUs and Lync on the H.264 protocol, that is native to Lync2013.
At this time, I have VCS-C X7.2 and Lync2013 RTM. On the video call without AMGW, call establishes like audio-only.
When using with Lync2010, this worked on H.263 protocol and CIF resolution.
Solved! Go to Solution.
10-20-2013 10:12 PM
Hi Mike,
yes, thats right..currently the Buzz around is for november.
Rgds
Alok
12-23-2013 12:04 PM
Is the Microsoft Interoperability option key required for Lync 2013 to VCS communication?
12-23-2013 03:12 PM
Yes, see page 244 of the admin guide;
/jens
Please rate replies and mark question(s) as "answered" if applicable.
12-23-2013 09:11 PM
I tried X8.1 - calls from Lync2013 on iPad to Cisco endpoints works fine, but calls from Lync2013 on android devices or iPhone (5) - fails =(
12-26-2013 05:58 AM
Does anyone know the product number for the Microsoft Interoperability option key to be ordered. I can not find it online.
12-26-2013 09:38 AM
Douglas -
In the VCS 8.1 release notes it states the Microsoft Interoperability option key is formerly known as the Enhanced Microsoft Collaboration option key. So unless they plan on changing part numbers, they might use the old OCS option key.
Cisco-VCS-Release-Note-X8-1.pdf, bottom of page 1.
12-27-2013 04:30 AM
Correct, it is same PID (Option key index is 116341C00) and will display as “Microsoft Interoperability” if VCS run with X8.1 software version.
So for those already have “Enhanced OCS Collaboration” option key installed, VCS will automatically update option key as “Microsoft Interoperability” once software is upgraded.
