Cisco VG 224 Analog Phone Gateway
egain.com
Can i use cisco vg224 gateway in a scenario like -
cisco ISR+CCM express -->WAN LINK --> cisco ISR -> VG224 gateway --> analog phones.
If this scenario is good then, can i do call transfer and forwarding with analog phones with any extensions digital/analog on that setup?
thanks
regards
Rakesh
pradeepde
Level 5
Level 5
The Cisco VG 224 is an analog voice gateway that manages up to 24 FXS ports for analog devices. Call control of the analog FXS ports is provided by Cisco CallManager or by a Cisco CallManager Express (Cisco CME) system. An SCCP telephony control (STC) application on the Cisco VG 224 functions as a a proxy to translate call-control messages between the call-control system (Cisco CallManager or Cisco CME) and the voice gateway.
This URL should help you:
http://www.cisco.com/en/US/products/ps6441/products_feature_guide09186a0080483a76.html
Thanks Pradeep.
One more doubt.. Does VG224 has FXO ports too? can it be used at both end of WAN link with FXO -FXS combination (one end VG224 can have 24 fxo ports connected to local pbx and other end will have VG224 with FXS port)
thanks
regards
Rakesh
