Cisco webex cloud registration for room kit plus
While trying to generate the 16 digit webex activation code for Cisco webex room kit plus,
I couldn't sign in to settings.webex.com
Please help
5 Replies 5
Jonathan Schulenberg
Assuming you have the appropriate device registration subscription, you need to configure the workspace and generate an activation code from https://admin.webex.com.
Thank you Jonatan...is subscription is required? And what kind of subscription..? even when I am going to join existing domain is subscription required?
Here's the data sheet for device registration: https://www.cisco.com/c/en/us/products/collateral/unified-communications/cisco-collaboration-flex-plan/datasheet-c78-742548.html
Many, but not all, of the current Collaboration Flex Plan annuity subscription offers include this. You should review your current subscription with your Cisco account team or partner to understand what you're entitled to.
https://www.cisco.com/c/en/us/products/unified-communications/collaboration-flex-plan/datasheet-listing.html
How to get Register Room Kit if can't login into https://admin.webex.com/login
Wayne DeNardi
You only need the activation code if you are registering the Room Kit Codec to the Webex Cloud.
If you are going to use it registered to another call control (CUCM, VCS, Expressway, or Standalone) you don't need to use the code at all, and can instead skip the startup wizard completely.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
