Cisco WebEX DX80 Registration
Amr Abdelazim
i am trying to register a Cisco WebEx DX80 to WebEx cloud but it give me a message Not able to contact Webex service. A firewall may be blocking this system from connecting
Jonathan Schulenberg
What software version is it on? I believe it needs to be 9.15 to know of the latest certificates being used. If older, download the software from Cisco.com and install locally or try using cloud upgrader.
11 Replies 11
The current software version is CE 9.7.1, i will try 9.15 and feedback you, but i found three files for version 9.15 which are cmterm-s52040ce9_15_16_5.k3.cop.sgn, cmterm-s52040ce9_15_16_5.k4.cop.sha512 and s52040ce9_15_16_5.pkg, should i use s52040ce9_15_16_5.pkg for the upgrade??
i had upgraded it to 9.15 and is registered successfully, many thanks for your support, have a nice day
It is likely that a firewall is blocking the traffic between your video conference endpoint and the Webex cloud. Please check with your firewall team to open the required ports for Webex endpoint registration and media.
For more information on the network requirements for Webex, please see the following link:
https://help.webex.com/en-us/article/WBX000028782/Network-Requirements-for-Webex-Services#id_134132
Additionally, as mentioned by @Jonathan Schulenberg, please try upgrading your DX80 to the latest firmware from the Cisco Software Center.
i tried to connect it to DSL router direct, but same issue found
paul-contos
I received a DX80 due to a shipping error last year.  The company that it was supposed to go to told me to keep it.  It's brand new and I'm trying to activate and register it but am unable to get past the screen which says that I'm being blocked by a firewall.  I called support but they won't support this machine anymore.  Is there any way to get this to connect to activate?  I would then have to download the updated system software.  Any help would be appreciated.  Thanks
The device cannot connect to the Webex service for registration, so you need to resolve this with your network administrator.
Response Signature
That date does not apply for DX80, it’s the DX70 that is listed in the announcement.
Response Signature
Thanks, @Roger Kallberg  For some reason, I had DX80 stuck in my mind.
Response Signature
paul-contos
Hi Nithin,
Thank you for the reply.  I have a business phone and internet through Verizon since I have a small business.  Would they be considered my network administrator.  I would love to be able to use this device.  Will it still work if it cannot be used with the Webex cloud after June 1st?
It seems the device is unable to reach the Webex services to complete registration after entering the 16-digit activation code. I recommend performing a factory reset and then trying to register the device again.
Apologies for the confusion earlier regarding the Webex support for DX 80.
Response Signature
