03-09-2023 10:54 AM
We recently enabled MS Teams calling (VIMT) in Control Hub so our Cisco video endpoints can call into MS Teams meeting. It worked great, but I mistakenly applied the policy to everyone using this command:
Grant-CsTeamsVideoInteropServicePolicy -PolicyName CiscoServiceProviderEnabled -Global
Does anyone know of a way to disable it globally and switch it to identity (per person only)
Solved! Go to Solution.
03-10-2023 05:43 AM
Good morning Roger, that made sense to me too but I didn't have any luck. I did find your command here: https://dialin.plcm.vc/teams/ps.html Which is supposed to: Reset global Video Interop Service Policy to default configuration
My Teams Admin was able to get it working with the following command.
Grant-CsTeamsVideoInteropServicePolicy -PolicyName $null -Global
Then you can check to see if it's turned off by using this command.
Get-CsTeamsVideoInteropServicePolicy Global | select *
After that we were able to assign it per user. I waited until next business day to confirm it was working, I've heard it can take hours to take effect.
I hope this helps someone out. Have a great day all
03-09-2023 11:21 PM
Isn't this a MS command? If yes, why are you asking this in a Cisco forum and not in a MS forum?
03-10-2023 05:47 AM
Hello b.winter, yes this is a Microsoft Powershell command. I was asking here because I'm hoping other Cisco Admins have run into this issue before. I know MS Teams calling is becoming more popular and I've always had good luck here. I posted the answer at the bottom. Have a good day
03-10-2023 05:54 AM
In only very few cases (as far as I have seen in the job), Cisco admin and MS admin wasn't the same guy. That's why it doesn't make sense, to ask Cisco admins how to configure MS, in my opinion.
03-10-2023 03:12 AM
I’m not a PowerShell expert but a quick google search doesn’t show an obvious result for removing the policy - which is odd, there must be one.
Unless someone else jumps in it may be faster to remove VIMT entirely and then set it up again.
03-10-2023 03:59 AM
I think you'd need to do this, but I'm not sure.
Grant-CsTeamsVideoInteropServicePolicy -PolicyName ServiceProviderDisabled -Global
This name of the policy is mention in this document in the example for "The tenant has a default interop service provider, but specific users (say IT folks) want to pilot another interop provider". Grant-CsTeamsVideoInteropServicePolicy
03-10-2023 05:43 AM
