01-08-2016 10:51 AM - edited 03-18-2019 05:24 AM
I have a customer with a MSE8000 chassis with multiple 8710 blades installed. Two of the blades are clustered, but running in locally managed mode. Checking to see if anyone has any experience with trying to set up the 8710 clustered blades in Conductor as remotely managed?
01-08-2016 11:12 AM
It it's possible as long as you have either the Select or the full version of Conductor, as clustered conference bridges aren't supported with the Essentials version. A remotely managed cluster should behave similarly to a locally managed cluster within Conductor, except Conductor will be managing the TelePresence Server's resources, see the TelePresence Server Remotely Managed Help Guide for reference.
01-08-2016 11:17 AM
Thanks for the information Patrick. Customer is using the full version Conductor system. Very much appreciated.
01-08-2016 12:57 PM
No problem, if you start to configure the MSE 8710 blades for remotely managed mode with Conductor and have issues, let us know.
If you don't need anything else, don't forget to mark relevant replies to help others that might have the same issue.
