CME SIP and SCCP
love2xlr8
I have a CME 7.0 and have Cisco IPphone registered using SCCP, however I need to add a 3rd party SIP device that requires SIP registration, If i configure the SIP registrar would it create any conflict of any kind ?
Tks
zahidanwar1
 In my view, it should not make any conflict because if we use SCCP for the internal network so we can deploy SIP Gateway which means you can also register with SIP registrar.
 SCCP works on port 2000 whereas SIP is on 5060 so just make sure your configuration should be correct on SIP Gateway.
 Use Registrar command in global config mode after SIP-UA command (see last paragraph of attachment from CVOICE book).
6 Replies 6
love2xlr8
Anyone ??? NO ?
https://supportforums.cisco.com/discussion/10563586/cme-third-party-sip-phones
For SIP CME configuration, you will find local phones can register to CME without the need of "authentication register" command.  The CME will authenticates the MAC address compare with the ARP request.
For remote phones that are NOT in the same subnet, SIP digest authentication is required.  You need username and password stored in the phone config file, and compare it against the voice register pool.
Without "authentication register", when you do a "debug ccsip message", you will see 401 Unauthorized for the remote phones.
"authentication register" is a global settings and will affect all phones.
Sample configuration
voice service voip
allow-connections sip to sip
sip
bind control source-interface vlan102
bind media source-interface vlan102
voice register global
mode cme
source-address 1.1.1.1 port 5060
max-dn 20
max-pool 20
authenticate register
voice register dn  1
number 1001
voice register pool  1
id mac 0011.2233.4455
type 3905
number 1 dn 1
dtmf-relay sip-notify
username 1001 password cisco
codec g711ulaw
I already have the config, i was looking for a more of a conflict running both on a CME 7.0.. I know CUCM runs it without any issues.
Thanks though..
Thanks NAGARAJAN, for your clarification
   guys,  you can find here more details on step by steps how let registered SIP Phone
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/99946-cme-sip-guide.html
Best Regards
Mamdouh Sharaf
zahidanwar1
