CME : Sip to H323 Problem
cm
HI all
CUCM-------------WAN-------VOIP-------------------------CME-----Pots
Above is my Scenario where I have  2 Remote site using CME and HQ CUCM 7. For toll bypass I am using SIP Trunk to route traffic from HQ  to Branch to make local call from Branches. 1 of 2 sites its working ok , But the Second Site although the calls are routing via SIP they unable to go out to POTS dial peer.
I have tried to compare the configs .the only difference from the workin site is that on the sip conf I have extracted the following, Site A does not Support the following commands.
NOT Supported
sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
( I have enclosed Debug from CME not work)
Could this be the problem
NOT WORKING - SITE  A
voice service voip
clid network-provided
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
--More--          sip
  registrar server
  asymmetric payload full
voice class codec 1
codec preference 1 g729br8
codec preference 2 g711ulaw
codec preference 3 g711alaw
sip-ua
WORKING - SITE B
voice service voip
sip
  registrar server
voice class codec 1
xiaobaibc
Maybe your cme is running on a 15.X ios?
try this:
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
  ipv4 X.X.X.X 255.255.255.255
no ip address trusted authenticate
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  registrar server expires max 300 min 60
  transport switch udp tcp
