CMR CLOUD
khan300
Dear Team,
My client already has a CUCM 10.5 in his network and I have suggested a CMR solution for him, the BOQ of which you can see in the BOQ. I have proposed SX20 for him along with 5 webex & CMR licenses. My question is firstly does the SX20 need a TP license ? If it does which one ? I have included the licese in the BOQ, so you can check if its the correct one or not.
Secondly, I know people who have a working solution without the TP license for the SX20, is it because its a RTU license or its not required for SX20?
Thirdly do i need an RMS license here ? Why exactly is an RMS license needed? My understanding is that it is needed to connect to someone outside the network. Since this is a CMR cloud solution and everyone will be connected by cloud , so no need for RMS right ?
Thank you
# Part Number Part Description Service Duration Quantity
1.0 L-WBX-MC-NU-NEW WebEx Named User MC - New Service - 1
1.1 L-WBX-AU-5K-NY1 New - Committed Audio 5K Min/Month - 1YR - 1
1.2 L-WBX-MC-NU-S2-NY1 New - MC Named User - Tier 2 (5 - 999 Users) - 1YR - 5
1.3 L-WBX-CMRNU-S2-NY1 New - CMR Cloud NU - Tier 2 (5 - 99 Users) - 1YR - 5
2.0 CTS-SX20-PHD4X-K9 SX20 Quick Set HD, NPP, 4x PHDCam, 1 mic, remote cntrl - 1
2.0.1 CON-SCTN-SX2PHD4X SMARTCAREVID 8X5XNBD SX20 Qk Set HD, NPP,4x PHDCam,1 mic RC 12 1
2.1 PWR-CORD-UK-A Pwr Cord UK 1.8m Black YP-61 To YC-12 - 1
2.2 CTS-QSC20-MIC Performance Microphone 20 - 1
2.2.0.1 CON-SCTN-QSC20MIC SMARTCAREVID 8X5XNBD Precision Microphone 20 12 1
2.3 CTS-CTRL-DVX-10 Touch 10 Control Device - selectable option - 1
2.3.0.1 CON-SCTN-CTLDV10 SMARTCAREVID 8X5XNBD Cisco Touch 10 inch 12 1
2.4 CTS-SX20-QS-WMK Wall Mount Kit for SX20 - 1
2.5 CTS-POE-INJ Touch10 PoE power injector - 1
2.6 LIC-SX20-PR Premium Resolution Option for SX20 - 1
2.7 CTS-QSC20-MIC+ Performance Mic - for auto expand only - 1
2.8 CAB-DV10-8M- 8 meter flat grey Ethernet cable for Touch 10 - 1
2.9 LIC-SX20-DD Dual Display Option for SX20 - 1
2.10 CTS-RMT-TRC5 Remote Control TRC 5 - 1
2.11 CTS-SX20CODEC-K9 SX20 Codec - encrypted - 1
2.12 LIC-S52010-TC-K9 License Key Software Encrypted - 1
2.13 LIC-SX20 SX20 License Key - 1
2.14 LIC-SX20-HD High Definition Feature for SX20 - 1
2.15 LIC-SX20-NPP SX20 Natural Presenter Package (NPP) Option - 1
2.16 CAB-DV10-4M 4 meter flat grey Ethernet cable for Touch 10 - 1
2.17 PWR-CORD-UK-A Pwr Cord UK 1.8m Black YP-61 To YC-12 - 1
2.18 BRKT-PHD4X-MONITR Bracket mounting for 4x PHDCam to monitor - 1
2.19 CAB-2HDMI-3M HDMI to HDMI cable - 2
2.20 CAB-HDMI-PHD4XS2 Custom 4xcamera cable; HDMI, Control and Power (3m) - 1
2.21 CTS-PHD1080P4XS2+ PrecisionHD Camera 1080p 4x SX20 auto expand - 1
2.22 SW-S52010-TC7-K9 SW Image for SX20 and MX200/300 (2nd gen) series endpoints - 1
3.0 R-UCL-UCM-LIC-K9 Top Level SKU For 9.x/10.x User License - eDelivery - 1
3.0.1 CON-ECMU-RUCLUCK9 SWSS UPGRADES Top Level SKU For 9. 12 1
3.1 LIC-TP-10X-ROOM Telepresence Room Based Endpoint, Single or Multi-Screen - 1
3.1.0.1 CON-ECMU-LICTP1RO SWSS UPGRADES Telepresence Room Ba 12 1
3.2 LIC-EXP-RMS Expressway Rich Media Session - 1
3.2.0.1 CON-ECMU-LICEXPRM SWSS UPGRADES Expressway Rich Media Session 12 1
3.3 EXPWY-VE-E-K9 Cisco Expressway-E Server, Virtual Edition - 1
3.4 EXPWY-VE-C-K9 Cisco Expressway-C Server, Virtual Edition - 1
3.5 SW-EXP-8.X-K9 Software Image for Expressway with Encryption, Version X8 - 1
3.6 CUCM-VERS-10.X CUCM Software Version 10.X - 1
3.7 LIC-EXP-GW Enable GW Feature (H323-SIP) - 2
3.8 PC-10X-STANDARD-K9 Prime Collaboration Standard 10.x - 1
3.9 LIC-EXP-AN Enable Advanced Networking Option - 1
3.10 LIC-EXP-E Enable Expressway-E Feature Set - 1
3.11 LIC-EXP-SERIES Enable Expressway Series Feature Set - 2
3.12 LIC-EXP-TURN Enable TURN Relay Option - 1
3.13 LIC-SW-EXP-K9 License Key Software Encrypted - 2
3.14 LIC-EXP-E-PAK Expressway Series, Expressway-E PAK - 1
3.15 UCM-PAK UCM 9X/10X/11X PAK - 1
2 Accepted Solutions
Talal,
For ability to make B2B calls or make call to number of SMR Cloud your client must deploy two VMs (Expressway-C and Expressway-E) . Each B2B call uses one separate RMS license for each Expressway server.
Each phone on CUCM requre license. Your "someone" may use Enhanced license on CUCM and use SX20 as third-party device, but its wrong way.
br Oleksandr
For CMR Cloud call from CUCM endpoints you need deploy Expressway-C/E and purchase RMS license.
Starting with X8.6.1, calls to cloud CMRs do not consume an RMS licenses, although under some certain circumstances it's still possible they could consume an RMS license, refer to the Expressway X8.6.1 Release Notes for more information.
6 Replies 6
Hello Talal
If you want register SX20 on CUCM you need purchase TP license for CUCM.
TP license is not RTU.
For CMR Cloud you can use SX20 standalone without CUCM and without  TP license :-)
br Oleksandr
We would need RMS license as well ? Why is that ? What's the purpose of RMS for this setup ?
Also I know someone who is using sx20 without a license and it's working with the cucm. And it's not on standalone.
Talal,
br Oleksandr
so your saying a ucl license is being used for the sx20? How can they even allow it to work ? It might be wrong but then again cisco shouldn't allow it to happen. They should only allow TP license to be registered with the sx20 not any UCL license.
Patrick,
Thanks you for update my knoweldges !
br Oleksandr
