04-29-2018 09:08 AM - edited 03-18-2019 02:04 PM
I have only one CMS 1000 server . but im really confused after reading the deployment guide on virtualized environment perspective.
does single combined server means all roles in one single VM in a physical server or separate roles in different VMs in a physical server (ucs 220 M4) ?
similarly does single split server means edge and core in separate VMs with corresponding roles as mentioned in the guide in a physical host (ucs 220 M4) ? or is it means 2 separate physical host server machine for core and edge server with corresponding roles?
I can see TURN server in both deployment types. TURN should be in the DMZ area right? in that case what is the difference between the two deployment? Both have edge concepts.
please clarify this doubt. I got really confused.
Solved! Go to Solution.
04-30-2018 06:59 AM
Here's the direct link:
https://salesconnect.cisco.com/open.html?c=25c8f919-dc63-498b-87e6-35beb1ddd48b
04-29-2018 12:51 PM
04-29-2018 05:31 PM - edited 04-29-2018 05:33 PM
"Single split server" is having "core" and "edge" functionality on different servers and no redundancy.
"Single combined server" is having both core + edge functionality in a single server (or not using edge functionality at all), with no redundancy.
"Scalable and resilient" deployments is having two or more CMS servers for redundancy, scalability or spreading load between sites.
All references are to virtual machines, rather than physical servers. You may choose to separate "Core" and "Edge" functionality on a single physical server, using multiple VMs, if you wish.
Also worth checking out are the CMS options with Expressway, where the "Edge" functionality is performed by Expressway rather than by a separate CMS instance: https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-9/CMS-Expressway-Deployment-Guide_X8-9-2.pdf
04-30-2018 04:47 AM
Is this without TURN server. i found TURN server still available in single combined deployment. how is that possible? single combined server will be in DC right instead of DMZ. so how TURN role come into play?
04-30-2018 04:50 AM
04-30-2018 05:14 AM
04-30-2018 05:24 AM
04-29-2018 06:31 PM
If you haven't, I strongly suggest you review the Collab250 training in SalesConnect.
04-30-2018 02:57 AM
Hi Jamie,
I am keep to get my hands on the COLLAB250 training. I checked on Sales Connect but it keeps saying invalid URL redirect. I was looking at the VOD link.
04-30-2018 06:59 AM
05-01-2018 03:42 AM
Thanks Jamie. I still get this error. Is there a permission restriction of some sort here?
05-01-2018 10:48 AM
I think you should have access to it:
Access Level: Partner, Distributor, Employee
PSS doesn't show a partner name for your CCO, there might be a problem there that's preventing you from accessing the course.
05-06-2018 01:03 PM
05-06-2018 02:59 PM
Not sure why it's not available for download, you'd need to ask the team in charge of that the reason.
1 CMS 1K = 1 CMS instance
Read here for recording specs
Cisco Meeting Server, Deployment Planning and Preparation Guide
05-07-2018 09:11 AM
