ā02-22-2017 12:59 PM - edited ā03-18-2019 06:55 AM
We've got CMS 2.1.3 (Single box deployment) with CUCM 11.5.1SU2 and expressway 8.9.
I am trying to allow outbound calls to be routed from our CMS to CUCM for further processing.
There is a secure sip trunk between the 2 and I am able to call from cucm endpoints to CMS spaces succesfully. Ad hoc conferencing is also working fine and the webrtc client as well.
I have 3 interfaces on the CMS : interface a for the admin, interface b for the callbridge,xmpp,webbridge and interface c for the turn server.
When an outbound call is made from CMS, I can see it is being rejected on CUCM because for some reason CMS is using the IP address of the turn server instead of the IP address of the callbridge.
Any ideas on how to resolve this one?
Jeroen
ā02-22-2017 01:16 PM
Sounds as if the call bridge might be configured to use the incorrect interface..
ā02-22-2017 01:43 PM
Hi Patrick,
Thanks for your reply. How can I define what interface to use?
Jeroen
ā02-22-2017 01:51 PM
Whenever you setup and activated the various CMS services, you must define an interface for it to use, refer to section 3 of the CMS 2.1, Single Combined Server Deployment Guide.
Also, check your configuration with the CMS 2.1 with CUCM Deployment Guide.
ā02-22-2017 01:54 PM
Hi Patrick,
Yes indeed, interface b is configured for call bridge use and interface c is configured for turn use.
I have now added the fqdn of the turn server to the secure sip trunk on CUCM like Oleksandr has suggested. This seems to work. the CUCM options ping is now reporting the trunk in partial state as of course there is no sip running on that interface on the CMS.
It sounds like this is a workaround for the moment but does not feel like a permanent solution.
Jeroen
ā02-22-2017 01:58 PM
Hi Jeroen,
CUCM can't accept call from unknown IP.
Maybe add additional IP in configuration CUCM SIP trunk ?
br Oleksandr
